Old 01-13-2019, 06:24 PM
Mattian Mattian is offline
Default Custom mapping plug in parameters
Hello, finally the dock has arrived and I like it
But there are few things I don’t like
I’d like to be able to map plug ins parameters as I wish
For example, with metric halo eq I’d like to be able to have a dedicated knob for Q parameter, instead pressing sel to control the Q
That’s one of the main reasons I wanted a controller
To be able to control Freq and Gain together with Q
Using two hands and tweaking two parameters I can have the sensibility of an analog console, but if I need to push sel to control the Q I won’t have the same sensibility and interaction of an analog console
Do you have any idea if I can do this? I want to be able to change the plug in mapping as I wish
Another disappointing thing is about editing, it doesn’t seem I’ll be able to use it for editing, seems still very much mouse dependent... and in general, first impression is I will still be very much mouse dependent, but maybe I just have to learn it a bit, but the soft keys section seems confusing
Also, having a touch display at hand, I thought the editing part was like more hand made touching the wave form to move it, zoom it, trim it, cutting and so on
It doesn’t seem possible, so avid, I’m giving you a great idea... make editing possible with hand gestures, cutting, trimming, everything needs to be made by hand, not using buttons on the screen to nudge and so on
Thanks
Old 01-18-2019, 11:29 PM
crustn crustn is offline
Default Re: Custom mapping plug in parameters
Hey Mattian,
This feature request exists for years now. It not possible on any eucon controller, S6 included. I lost confidence that this will ever be implemented. Obviously it’s not as easy to program. So maybe someday in the next 20 years.
I just wonder why Avid is not allowing to edit the pagetable.xml in the aax plugin by the user. This would be so easy...
Old 01-22-2019, 02:03 AM
Yeah... and actually now a bigger problem is knobs... I’d like to customize speed and sensitivity... they are not much usable, you can’t trust them and mix closed eyes
Old 01-23-2019, 09:28 AM
EddieJones's Avatar
What verison of EuControl are you using ?
Old 03-28-2019, 03:31 PM
I'm using the last one, sorry I didn't expect to receive an answer because I hadn't seen much interest on this forum about the dock
but thank you very much for the reply
I'm trying working with the dock but I think it has many aspects that should be improved, it's a great idea and I see a lot of potential
So, if you need someone to expand the use of the dock and iPad, I'm available
For example, the iPad could be used to do editing by hand and to have an "instinctive" direct transport control
The knobs need to have references, in general everything needs to have references, so you can mix without watching or watching much less than you do know
Many ideas come to mind about how to do these things, so I'm constructively available, if you need
Old 05-13-2021, 09:02 AM
lydpik lydpik is offline
Now here in 2021 has this issue been solved? Are plugin parameters still randomly spread out on the S series so I will have to bank page after page? I hated that with the Artist series. Has there been any development?
Sorry for any bad grammar/spelling, I'm not from around here.
Old 05-13-2021, 09:57 AM
EddieJones's Avatar
End of June....
Old 05-13-2021, 04:53 PM
mattrixx mattrixx is offline
Yay!! Definitely exciting times!!
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 05-25-2021, 08:05 AM
reichman's Avatar
reichman reichman is offline
I am running the demo of DMG's amazing Multiplicity plug-in and literally waiting to buy it until I know custom mapping is coming. The plug-in is almost unusable on a surface right now. Can't wait Eddie!
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 05-25-2021, 01:19 PM
EddieJones's Avatar
Its not even tagged as an EQ or have a graph in EUCON. You should ping them and let them know too.
Avid Artist Control custom plugin parameters tijn1311 Artist Series 6 08-08-2016 03:55 PM
Mapping to custom faders dunebuggy Pro Tools 10 4 06-29-2015 08:51 AM
Custom Plugin Mapping with Nuendo? J-S-Q Artist Series 2 04-23-2015 03:02 AM
Artist Mix and Channelstrip not mapping all parameters PT11 JohnnyB Artist Series 1 07-12-2014 04:57 AM
Request for Custom Surround Mapping mavericksound Post - Surround - Video 2 04-22-2007 09:51 AM
