Old 11-14-2017, 07:13 AM
Isadore Isadore is offline
Default problem with importing a cd track into a PT session
hi folks, I don't know if I am importing an audio track from a cd into a PT 12.5.2 session correctly. I think I am the instructions correctly, on Toast 14 Titanium but something isn't right about it. It has a clicking or snapping sound when I play it back. I ran an old PT 5.6 and old Toast program for many years and with that, Toast would extract the tract from the cd and import it in the session. The Toast 14 doesn't seem have the option of that. I'm probably overlooking something obvious. BTW I'm using a Mac.
thanks for your help
Bill Mize
Old 11-14-2017, 07:23 AM
john1192 john1192 is offline
Default Re: problem with importing a cd tract into a PT session
hi, we could use some additional information .. ie: you tried everything to make it work, and that the CD plays correctly in your MAc BEFORE you try and import it .. then try below ..
Try #1 - if that is causing Clicks and Pops, then i would use #2 and check it with Quickview (highlighting the file and hitting spacebar) and make sure it plays correctly on the Mac, if you think it is PT (eliminate PT from the equation) .. if still bad then use #3 Toast and see what happens ...
1) you can use File / Import Audio / and point to the CD track Directly into PT
2) you can import the CD directly to your Mac .. and then import into PT ..
3) or use Toast to import and then import into PT ..
cheers john
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 11-14-2017, 07:47 AM
Sardi Sardi is offline
As John pointed out, scrap Toast altogether and just drag and drop directly into your Pro Tools session from the mounted disc on your Mac.
Doesn't get any simpler than that. :)
Old 11-14-2017, 08:13 AM
thanks for the replies guys, John, I played the cd through the Mac and it sounded fine. I think the problem lies in the convert/import step. It will appear in the box and I listen to it then and it clicks and pops.( before I convert it) and also when I convert it and import it to a track. Sardi, the drag and drop does work fine. I guess I thought it had to be converted first. thanks again
Bill Mize
Old 11-14-2017, 08:15 AM
ok, so you are sorted BUT you are getting Clicks and Pops is what Box ??? in Pro TOols Import Audio ?? or on the Mac ?? please let us know for the Next person that has this issue !! cheers john
RME BabyFace Pro
RME BabyFace Pro
Old 11-14-2017, 02:32 PM
yes, I was referring to the file/import audio draw down box in the PT session where you select the file you want to import.
Bill Mize
Old 11-14-2017, 02:43 PM
Lets make this very easy.
Exit Pro Tools.
In iTunes Preferences set the input format to AIFF.
Import the CD track into iTunes.
Play that file in iTunes, does it play OK? If not you have a problem outside Pro Tools. Try checking the "use error correcting" option in import preferences in iTunes if you have problems.
Start Pro Tools and open the session you want to import to.
Find that AIFF file icon in the finder and drag and drop it into your Pro Tools session Mix window (doing that will create a audio track or you can drag it onto an existing audio track if you want to place it there).
Importing track with inactive bus kills bus in current session dj_grimmace macOS 2 03-22-2013 11:26 AM
exporting one track from a session and importing to another Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-08-2009 05:05 AM
Importing a Midi Track from another session markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-22-2004 06:31 AM
Problem importing LE5.0 session into TDM/Mix Keith B Pro Tools TDM Systems (Mac) 1 03-29-2002 08:47 AM
Importing a Midi Track from one session to another...How? Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-03-2001 12:05 AM
