Old 08-28-2017, 06:26 AM
audioman1973 audioman1973 is offline
Default Dock possible with Protools 12.4
I know Dock shows Avid supports it beginning with Protools 12.5. Is anyone using it successfully with Protools 12.4?
Pro Tools Ultimate 2023.9. Mac Studio M2 128GB Ram 24 Cores 4 TB HDD. 2 Universal Audio Satellites. Lynx Aurora N.
Old 08-28-2017, 08:57 AM
SteSo SteSo is offline
Default Re: Dock possible with Protools 12.4
I do use it with PT 11.3.2.
Old 08-28-2017, 10:53 AM
Thanks!
Old 08-28-2017, 06:41 PM
EddieJones's Avatar
It should work but you may be missing a feature or bug fix etc.
Old 11-06-2017, 09:09 AM
I just received my Dock last week so I went to Protools 12.7.1 which is the latest version I have access to. Also installed Eucontrol 3.7 on my PC and Pro Control on the iPad. So far 12.7.1 seems to be behaving but trying to work through connectivity issues with the Dock. Specifically the error message other folks are seeing about the versions of Procontrol and Eucontrol not being compatible when they both show the same versions installed and also the Dock not connecting after PC boot sometimes even when I had it powered on before starting the computer. I seem to get it to connect by using the Eucontrol start method. I also set up the network connection to the iPad hardwired instead of using WiFi since I live in the country and don’t have unlimited data usage. Seems to be working well. I will try some of the solutions I’ve read in other posts here when I get a chance. When I have it running though I’m loving it. Can’t wait until I get used to it and my workflow becomes second nature!
Does the Avid Transport work with S3+Protools Dock TrackerLe Avid Pro Mixing General Discussion 10 08-11-2017 12:19 AM
Protools Dock Wawili_Sound Pro Tools 12 8 07-19-2017 08:47 PM
Protools | Dock design issues Cryos Avid S1, S3, Dock and Control App 5 01-09-2017 01:00 AM
OSX 10.4 ProTools LE 7.3 Launch Failure/Bouncing Icon on Dock JohnColtrane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-29-2008 12:22 PM
ProTools aqua icon for dock! 8trackmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-19-2003 01:28 AM
