Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 12-11-2024, 06:22 PM
heph heph is offline
Default Carbon + SD3 + MIDI Performance
Just wondering if anyone has tried this on the Carbon System and if the DSP was available/ worked for this application.
I am keen to see if the Carbon would significantly lower the latency of SD3 performances when hooking up a Roland TD30 (or comparable brain). Currently I am recording the MIDI performance with the drummer listening to the Roland sounds but triggering the SD3 sample libraries 'after the fact'.
This is by no means awful but it would definitely be better if the drummer was listening to the final kit.
Has anyone used this sort of setup and are there any issues or words of advice about this?
Currently I am using an OMNI with HD NATIVE card and a Mac MINI M2Pro
Even with the buffer sizes changed it isn't great for latency
Old 12-11-2024, 06:47 PM
Default Re: Carbon + SD3 + MIDI Performance
HDX DSP processing is not going to help MIDI and sample based VI latency.
Old 12-12-2024, 08:24 AM
dominicperry dominicperry is offline
Absolutely not.
SD3 has huge, huge samples - Carbon cannot load any samples of any kind into DSP.
On top of that, the VI latency from computer to Carbon is not particularly low.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Sequoia 15.2, Pro Tools 2024.10.2, Carbon.
Old 12-12-2024, 12:32 PM
nst7 nst7 is offline
As mentioned, it won't help with listening to the SD3 samples, but it would still be an improvement over your current system, in that the DSP would help you achieve low latency of the audio signal from the Roland (along with recording the midi). You would then use the midi to trigger the samples like you are doing now.
Performance Degradation with Carbon and Sonoma? massivekerry Pro Tools | Carbon 25 10-28-2024 01:14 PM
Carbon / AVB performance woes martthie_08 Pro Tools | Carbon 7 09-09-2024 06:05 AM
Pro Tools | Carbon & Carbon Pre compatibility with AVID S4 Control Surface [email protected] Pro Tools | Carbon 9 09-14-2023 10:36 AM
Poor performance from Spectrasonics with Mac Pro and Carbon dominicperry Pro Tools | Carbon 7 08-30-2021 12:41 PM
Native Monitoring/recording performance under Carbon? Ru_C Pro Tools HDX & HD Native Systems (Mac) 1 08-16-2021 07:36 AM
