Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 04-21-2024, 10:38 AM
jschmit jschmit is offline
Default MTRX Studio Monitoring via Dante
I'm exploring the possibility of creating an alternate 5.1 monitoring path out of the MTRX Studio via Dante to a Powersoft DSP 4k4 amp. I'm not sure where to start with this. Do I connect both units to a separate switch and then configure this in DADman? Do I also need virtual DANTE software from Audinate to make this work?
Mac mini i7, OS 14.4.1, MTRX Studio via HD Native Thunderbolt, PT Ultimate 2024.3.1, Avid Dock and S1.
Old 04-21-2024, 10:45 AM
tope d's Avatar
tope d tope d is offline
Default Re: MTRX Studio Monitoring via Dante
Hi. This thread might help https://duc.avid.com/showthread.php?t=419064
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 04-21-2024, 12:40 PM
No. You would not normally use DVS, that is a (not great) connection between your Mac and the interface, you already have that connection with HD Native assuming you have enough I/O there. And if you are out of I/O capacity on HD Native I would be looking at going Thunderbolt.
You don't need a switch if just connecting two devices. Run the MTRX Studio in switched mode with the Mac connected to Port 1 for Control and the DSP 4K4 DSP+D amplifier connected to Port 2.
Old 04-22-2024, 12:02 PM
Thanks! I’ll give that a try.
Old 04-22-2024, 12:17 PM
its2loud its2loud is offline
Your monitoring paths can be any available output from the MTRX Studio. You just need to configure this in DADMan. You assign your speaker outputs to the Dante outs of the MTRX. Both the MTRX and the Powersoft unit would need to be on the same Dante network. This could be done with a passive ethernet switch. I'm not familiar the patching capabilities of the Powersoft unit but you can patch all the Dante with Audinate's free Dante Controller software.
Dante SRC on MTRX Studio ViciousLullabyz Pro Tools | MTRX & MTRX Studio 4 02-04-2022 04:00 PM
MADI - DANTE for MTRX Studio AINSLIE Pro Tools | MTRX & MTRX Studio 3 10-29-2021 06:49 AM
S6 and MTRX monitoring - Trinnov Dante Insert? acacia Avid S4/S6 8 08-22-2021 03:31 PM
MTRX Studio using Dante only c-tone Pro Tools | MTRX & MTRX Studio 15 08-20-2021 03:00 PM
MTRX Studio with Dante PCIe in a new Mac Pro joepopp Pro Tools | MTRX & MTRX Studio 5 04-30-2021 05:00 AM
