2 MTRX Studio - Which version of PT needed?
Hi, I've got one MTRX Studio and and HD I/O w 16 Analog I/O. Found out that I need PT Ultimate to use the HD I/O. As i have PT Studio only at the moment, considering my options to get to 32 AD/DA (at 96khz).
Will I be able to use two MTRX Studios with PT Studio, or will I still need to buy PT Ultimate? Also, current MTRX Studio has TB3 card, but would i be able to link the MTRX Studio units with the mini digilink cable? Many thanks, Pat |
Re: 2 MTRX Studio - Which version of PT needed?
You cannot use digilink without HDX or HD Native. You also need Pro Tools Ultimate to use either of those options.
To add to the conversation...
Pro Tools Ultimate: DigiLink IO via HDX HDN engine TB3 IO via TB3 engine IP Audio via Dante engine (assumes software or hardware host interface) Pro Tools Studio: TB3 IO via TB3 engine (one or multiple MTRX devices) IP Audio via Dante engine (assumes software or hardware host interface) best, Jeff |
On the software side: Pro Tools Studio will work with a MTRX Studio with DVS as playback engine (too much latency for tracking audio) or if it has the Thunderbolt3 module installed, with the MTRX Studio Thunderbolt3 as playback engine. You cannot use the HD I/O with Pro Tools Studio because the HD I/O needs HD native or HDX to interface with and HD Native and HDX are only selectable as playback engine in Pro Tools Ultimate when there's also a digilink license present on your iLok So, if you want to use the digilink ports on both units to have 32 channels of analog I/O you can only do so by using Pro Tools Ultimate, having an HDX card or HD Native thunderbolt interface present and also you need to have a Digilink license on your iLok.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3 |
--- Since the OP is asking how to get 32x32 physical I/O with these systems and Pro Tools Studio, the answer there depends on exactly what you want to do. Be careful of getting stuck with complexity with hardware routing/monitoring and introducing latency differences, including if you want to use these boxes with hardware inserts. You could span two systems systems together with say Dante and DADman (I'd not) but again depends on what you want to do this for, as you'll see latency there over Dante. You could use macOS aggregate I/O and two MTRX studio connected to a Mac via thunderbolt. But if there are problems there with aggregation you'll likely on your own. And at the point of purchasing two MTRX studios you are maybe just better off buying a MTRX II and adding $$$ preamp/line modules, or maybe looking for alternative options like a Lynx Aurora (n) 32x32 with Thunderbolt card (caution there on the number of folks who seem to have hardware insert/ADC latency issues with the Lynx Aurora (n)). Or since I'm an RME fan boi I'd consider a MADI card set/interface and a M32 Pro AD and M32 Pro DA. Prices for some of these very nice boxes might make you reconsider purchasing Pro Tools Ultimate and going with used HD I/O. But with HDN being past end of sale life and the problems that Avid has with HD Driver support I'd personally be moving away from Digilink unless I really needed HDX/DSP for tracking. |
ah! wasn't aware that digilink licenses have become a thing of the past:)
Thinking out loud, but I've never tried this because I only have a MTRX, can you hook up a HD I/O to the digilink port of a MTRX (studio) and patch it to Dante or Thunderbolt (if TB3 module present) ? Or, and I guess I remember reading this somewhere long ago, does usage of digilink ports always at least require 1 digilink host (so HDX of the current available options) to receive proper clocking
Thank-you for confirming!
MTRX and MTRX STUDIO together? | kingtone | Pro Tools | MTRX & MTRX Studio | 4 | 06-05-2023 04:32 PM |
Difference between MTRX and MTRX Studio? | snowplaysmusic | Pro Tools | MTRX & MTRX Studio | 4 | 11-26-2022 09:48 AM |
MTRX MTRX Studio Forum Section? | off the wall | Pro Tools | MTRX & MTRX Studio | 2 | 05-08-2022 04:20 PM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 12:00 PM |
Protools MTRX / SyncHD Still Needed? | Nathan W. | Post - Surround - Video | 16 | 07-14-2017 05:12 AM |
