batch fade
does le have batch fade? I cant find it...I seem to be able to fade multiple but dont understand what batch fade is.
Re: batch fade
How about looking it up in your manual.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Re: batch fade
Geez Ben, ease up a little. What exactly are you trying to accomplish with a batch fade?
Re: batch fade
Ben is right though: I don't see how anyone of us could describe it more precisely than the manual.
There is an index at the end of the manual, search for "batch fades". The paragraph is not even a page long. Read it and then experience with it on a new "test" session. Should take you about 5 mn to become a professional batch fader for life. Worth it, huh? Then, if there is anything you still don't understand, come here and ask for a precise detailed question. Let us know how it goes. |
Re: batch fade
... the manual was not clear as to if Batch was TDM only or not and in my confusion while reding the manual I tried to look for a batch fade feature in the interface...but could not find it.
Prefs..Fade dialog...Menu...Ect. |
Re: batch fade
Set your fade prefs in the preferences.
Select the regions across where you want to fade. Press Control+Option+Command+F ---- Rail
Re: batch fade
Thanks Rail ...you are a man of many elements....and key combinations
Re: batch fade
The trick when you read the manual is to have a "test" session open in front of you with "test" audio files. That way, you can try out everything the manual explains, see how it works... I know I always do that.
Otherwise, I read the manual and things just slide on me! |
Re: batch fade
WARNING:
When you aply a fade over multiple edit points, the first and last edit points do not fade correctly. It is a bug and has not been fixed yet. |
Re: batch fade
Yes: I set my nudge to the value of the fades, TAB to the end, CMD-OPT-"-", CMD-F.
Amongst other things.
Music is a higher revelation than philosophy. - Beethoven |
Batch fade-out | SteveFireland | Tips & Tricks | 4 | 12-20-2012 05:32 PM |
Batch Fade in / outs | TCLguy1 | Pro Tools TDM Systems (Mac) | 12 | 11-12-2010 08:33 AM |
Batch Fade Question | AURORA4DTH | Pro Tools TDM Systems (Mac) | 3 | 03-18-2010 09:42 AM |
Feature Request Batch Fade In and Batch Fade Out | mariang | Pro Tools TDM Systems (Mac) | 2 | 02-07-2007 01:32 AM |
Why does batch-fade leave out first and last fade? | Frank Kruse | Post - Surround - Video | 5 | 03-08-2006 03:47 PM |
