  #4701
Old 02-17-2012, 02:57 PM
Default Re: i7 Builds - Specs and Results
Originally Posted by arhall View Post
Not any more. Had some -9128 but I think I've solved most of the problem now. But I found this link and got curious.
Generally, if there was a problem that required such action, everyone running a USB device on Windows 7 would have the same issue. I would stay clear. Could get you into more trouble than what it is worth.
Aaron Mulqueen - 001 HD Native
  #4702
Old 02-18-2012, 10:18 AM
Sawllkwa Sawllkwa is offline
Originally Posted by albee1952 View Post
I am running that very combo with solid performance here. While its considered "old" in computer lingo, its a well proven package with either 6 or 12GB of triple-channel RAM. Dropping the cpu into the socket is simple(if its NOT simple, you're doing it wrong). Newegg.com has tutorial videos on building a rig, or youtube is another great source of help. The cpu has a marking on one corner, as does the socket. Go slow, be careful, pay attention and all should be fine(I've built about 16 machines over the last 6 years and have not screwed one up yet). I bet you hear me knocking on wood
Yeah lots of good vids on newegg and youtube. I was super nervous too (my first cpu drop) and I think I watched every video I found :)
On my friends suggestion, I even removed the 'factory installed' cpu heat paste, and used another he gave me. He builds computers to run nuclear reactors, so I trusted his word :P
Intel Core i7-3930K, ASUS P9X79 WS, 2 x Corsair Vengeance 16GB DDR3, Intel Intern SSD 120GB (for OS), 500 GD SATA WD drive, Nvidia GeForce 8800 GTS, W7 x64, PT10 on a 002R
  #4703
Old 02-20-2012, 05:16 AM
ANP57 ANP57 is offline
After going through this great thread during past couple of weeks I´ve decided to upgrade my 2007 Core2Quad system. I´d like to to build it around the very common Gigabyte board. The tricky part is that GA-X58A-UD3R seems to be nowadays unavailable in Europe - at least in most places. Therefore I guess I´m safe with GA-X58A-UD5 rev 2.0 am I?
Here my proposal. Feel free to comment and give feedback. I´m kinda looking for the best bang for the buck and also trying to avoid the sleepless nights trying to stabilize the system
  • Motherboard GIGABYTE GA-X58A-UD5 rev 2.0
  • Intel Core i7-960 - 3.2 GHz - Cache L3 8 Mt - Socket LGA 1366 (box)
  • Cooler Coolermaster Hyper TX3 EVO
  • Video Card ASUS GeForce 210 SILENT - 1 Gt GDDR3 - PCI-Express 2.0 (EN210 SILENT/DI/1GD3/V2(LP))
  • Memory Corsair Vengeance 12 GB Kit PC3-12800, 1600MHz, 3x240 DIMM 12 GB Kit(3x4096 MB)
  • System HD Seagate Barracuda 7200.10 320GB Serial-ATA-II 16MB cache (recycled)
  • Sample HD Seagate Barracuda 7200.14 - 1T - SATA 6 Gt/S - 7200 T/M - 64 Mt CACHE
  • Audio HD Seagate Barracuda 7200.14 - 1T - SATA 6 Gt/S - 7200 T/M - 64 Mt CACHE
I´m hoping the be able to use my old case and psu. This would be Antec Sonata 2 450W, ATX12V v2.01. Do you see problems with the power supplly not being powerfull enough? I´m not going to overclock the pc at least in first place.
Is there huge benefit from doubling the memory up to 24 Gb? I´m typically not using a lot of VI´s in sessions. Some occasional Strike or BFD2 every now and then.
Other facts:
Interface 002R
Command 8
WIN7 Ultimate 64bit
Pro Tools 10
What should I except the Dverb result be with the specs above?
Thanks a lot!
  #4704
Old 02-20-2012, 06:38 AM
mano111 mano111 is offline
The UD5 had known issues in the past with noises in DAW. I'd stay away. If you can't get your hands on a UD3R then you can try the Asus P6T.
  • Quote:
That cooler is not a good choice IMO. Try the Cooler Master Hyper 212, or a better Noctua or similar tower with a quiet 12cm fan
The 450W Antec PSU that comes with the Sonata II is borderline for this system. My bet is it will work as it is fairly efficient and your video card power draw is low. Since you are only reusing the case + PSU and a single HDD I strongly recommend you get a new Case + ~600W PSU + a system HDD. That way you get to keep your quad core system for other uses.
Only reason I can think of for getting more RAM is if your using RAM intensive VIs. I'd keep it at 12GB.
Other facts:
Interface 002R
Command 8
WIN7 Ultimate 64bit
Pro Tools 10
Thanks a lot!
Good luck with your build. I'd expect ~300-350 dverbs based on similar systems scores.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #4705
Old 02-20-2012, 06:53 AM
Good advice^^^^re. the power supply. I have an i7 950 on the UD3R(works great) and the cpu can pull 18 amps by itself, then add the drives and fans. Take a look at the +12V spec on your old PSU as I expect the 960 can pull the same or a little more. Since I am not overclocking, I ran the stock cooler here with no issues. In the name of "quiet", I went with a Corsair h60 liquid cooler.
  #4706
Old 02-20-2012, 11:29 AM
mykhal c's Avatar
mykhal c mykhal c is offline
i7 3820...they're here http://www.newegg.com/Product/Produc...82E16819115229
Intel® Core™ i7 Desktop Processor Family
and this looks very interestin'
...first time seein' it but looks it could be a super time saver when changin' to a new build...http://www.newegg.com/Product/Produc...82E16832300022
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #4707
Old 02-20-2012, 12:10 PM
jello jello is offline
[QUOTE=jello;1899385]
Intel® Core i7-3930K Processor
ASUS P9X79 WS, Socket-2011
Corsair Vengeance DDR3 1600MHz 16GB CL9 (2x 32gig total)
Corsair H80 Hydro Series
ASUS Radeon HD 6450 512MB DDR3 Silent
Corsair AX 850W PSU
Corsair Obsidian 800D Big Tower
WD caviar black 500 gig system 32mb cache
WD caviar black 1000 gig audio 64mb cache
Protools 10, digi 002.
I have put my Corsair rig together, got my siig FW card today and did some tests. For now I am using an old WD caviar black 32mb cache drive from the old system, I think the performance will be even higher when I get a new hardrive for my system, any ssd drives that will get the job done?
On my i7 970/gigabyte rig I got 400 dverbs 1024 buffer which was good.
On my i7 3930K/asus rig I got:
1024 buffer: 660 dverbs which is HIGH. CPU meter at 95%. I used 11cores 99% instead of 12cores 90% (the highest setting), plugin streaming buffer at default.
64 buffer: 484 dverbs which also is very high. CPU meter at 83%. I used 12cores at 90%, plugin streaming buffer at default.
My corsair H100 cpu fan was making alot of noise at 100%, it is silent at low fan setting, cpu at 70 degrees.
With 32gig of ram I think its time to buy CPTK and get some disk cache.
I also tried the TPU overclocking feature and got the pc clocked to 4.9gigI used that insane clocking on the dverb tests. Great build!
Big thanks to Sawllkwa for the idea that something like this is possible.
  #4708
Old 02-21-2012, 06:15 AM
Thanks mano and albee!
Asus P6T seems to be hard to find as well. How about the P6T WS Professional or P6TD Deluxe? The Deluxe model seems have the different VIA FW controller than P6T. And WS professional comes with LSI FW controller...
P6TS WS Professional
http://www.asus.com/Motherboards/Int..._Professional/
P6TD Deluxe
http://www.asus.com/Motherboards/Int...6/P6TD_Deluxe/
Which one do you guys recommend?
  #4709
Old 02-21-2012, 11:03 AM
I'm not the final word on this, but I think the Deluxe would work fine, while the other model looks to have stuff you don't need(or do you need SAS or PCI-X?). As for the firewire, a $50 SIIG card is always an option if the onboard FW doesn't work Remember that you may need to "do a little dance" with firewire drivers(IOW, try the 3 drivers that are available on your system).
  #4710
Old 02-21-2012, 04:58 PM
Workstation for any DAW. Higher quality components, higher levels of Qualified vendors. Higher level of testing. Pro Tools, amongst others are high end digital audio workstation applications that require the best quality.
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
