Old 07-12-2007, 03:39 PM
Ted Spencer Ted Spencer is offline
Default Can\'t import QuickTime into FCP
I am unable to open a 30 minute quicktime movie I generated in PT via the bounce to QT Movie command. I was able to open a 3 1/2 minute one using the exact same method, but the 30 minute one won't open after two separate (hour long!) attempts. In FCP, when I try to import the clip as a file into the browser (using import/file dropdown) I get the following error message:
File Error: 1 file(s) recognized, 0 access denied, 1 unknown.
Anyone know what the problem is and how to solve it?
Thanks
Ted Spencer, NYC
tedspencerrecording.com
Old 07-12-2007, 03:44 PM
DigiTechSupt's Avatar
Default Re: Can\'t import QuickTime into FCP
Does the file open in Quicktime itself? If so, you may be able to re-save it from Quicktime and be able to open it in FCP.
What version of FCP are you running?
I've come across this on occasion - not sure what causes it, but it doesn't seem to be exclusive to Pro Tools, as I've had the same problem with video created from other apps. Almost every time I've been able to open in QT and re-save or re-export and be able to open the saved/exported version in FCP.
Avid Audio Tech Support
Support FAQ
Old 07-16-2007, 11:11 AM
RecRoom RecRoom is offline
I get this a lot when receiving quicktimes and MPEGs from different sources. You'd probably be better off going to a FCP help board for an explanation, but usually re-encoding in QT Pro or MPEG streamclip fixes the problem for me. I recommend MPEG Streamclip.
Jeff Hinton
Editor/Mixer
http://www.jeffhinton.tv
HTML code is On
Why can't I import more than one Quicktime movie? Nawlins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-19-2007 02:39 PM
QuickTime movie can not import. rollemk Pro Tools TDM Systems (Mac) 2 10-20-2006 08:27 AM
quicktime mov will not import dekype Pro Tools TDM Systems (Mac) 1 10-04-2006 06:25 PM
Can u import more than 1 Quicktime movie? johnnyv Pro Tools TDM Systems (Mac) 7 07-27-2005 08:54 AM
Quicktime import problem Breck Pro Tools TDM Systems (Mac) 4 06-15-2004 01:19 PM
