Old 02-01-2008, 09:51 AM
Dopamine Dopamine is offline
Default \"logical end of file reached\" - error opening an older PT 5
I can't open a PT 5.0 session, and keep getting that error. Anyone know of a workaround? "Import session data" didn't work either. 8(
http://www.phuturetrax.com
Old 02-01-2008, 12:17 PM
DigiTechSupt's Avatar
Default Re: \"logical end of file reached\" - error opening an older PT 5
Where did this session come from? How was it stored? How did you get it to this computer (network, CD, DVD)?
Do all files have their proper extensions?
Usually this error means nothing good - the file is corrupted or has had it's resource fork removed, either by incorrect storage (on a PC volume) or by being transmitted uncompressed over a network (not all cases will cause this, but it's usually a factor).
Avid Audio Tech Support
Support FAQ
Old 02-10-2008, 02:24 AM
Bennie Cook Bennie Cook is offline
I have the same problem. The session I'm working on comes from a Mac running PT LE 6.4. The session was exported via Save Session Copy In with the 'enforce Mac/PC compatability' option checked as this was destined to be finished on a PC running PT LE 7.1. The session was transferred to the PC via a USB memory stick in ms-dos FAT32 format. The session didn't open on the PC, Pro Tools complained about reaching the end of the stream. So I tried opening the session on a Mac running PT LE 7.3.1 and got a "logical end of file reached' error.
I can confirm that the resource fork metadata file ("._<session_name>") shows up in Windows, so it hasn't been lost. I haven't yet been able to get back into the studio this session was originally created in to check it there.
Anyway, my question is, is this the wrong way to transfer data from one system to another? If so, what would be the correct way to do this?
Bennie Cook
The Audio Workshop
Old 02-10-2008, 11:37 AM
Ale Ale is offline
I had this happening when transfering a session via a pc server.
there was no chance to get the session back to live.
Always zip before tranfering to pc.
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
SD2 file reached logical end? jackjamesdrums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-02-2012 02:40 AM
Error code -39 Logical end of file reached?? vanhanson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-15-2006 04:55 PM
Logical End-OF-File reached (-39) destudio Pro Tools TDM Systems (Mac) 2 12-28-2005 09:42 AM
Error: "Logical end-of-file reached" -39 Voxer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-24-2004 11:00 PM
Reached logical end of file -39 Giles Pro Tools TDM Systems (Mac) 4 09-18-2003 08:28 AM
