Old 09-14-2021, 11:04 AM
quangaroo quangaroo is offline
Default Who else is still using a Mac Pro 5,1 or older computer?
I used to be one of those folks that always upgraded/updated my OS & hardware, but when Apple introduced the "garbage can" Mac Pro, I jumped off that merry-go-round.
I have a 2012 MP 5,1 running macOS 10.13.6 with PT 2019.5 and a 2009 MP (firmware upgraded to 5,1) running Mojave that I use as both a back-up machine and a testing ground for new OS's & software. My main interface is a Digi 003 Rack and the back-up computer has a Digi 003 Rack+.
Both systems have upgraded metal GPU's and 48GB of RAM and I suppose they are getting long in the tooth (sometimes there's new updates or plug-ins for things like FCPX that won't run on them), but I use PT daily and there's nothing like having a stable, solid system that just works. I know I'll probably buy the M1 Mac Pro at some pot, but I'll also be keeping one of my MP 5,1's as a back-up!
Mac Pro 5,1 (Mid 2012) | macOS 10.13.6 | 48GB RAM // Pro Tools 2019.5.0 | Digi 003 Rack | Digi 003 Rack+
Old 09-14-2021, 11:59 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Who else is still using a Mac Pro 5,1 or older computer?
2010 5,1 HDX, 64gb
Holding at macOS 10.14.6 Mojave.
Ultimate 2021.7
Rx580 flashed
Running well.
Old 09-14-2021, 07:41 PM
TheFilterLab TheFilterLab is offline
I'm still on a 2010 5,1 running Mojave PT 2020.9 HDN. I also have another 2010 5,1 system here on High Sierra with PT 2021.3 HDX.
Both systems are working great and i don't feel the need to upgrade the computers anytime soon (they are both 3.46GHz 12 cores). I'm considering giving Opencore a try to see how feasible Catalina is. I'll probably jump up in PT version at some point too. I'm in no rush to be part of the new wave of computers. I'll wait until I need to make the jump and hopefully things will have leveled off a bit.
Old 09-15-2021, 03:26 AM
Will Russell's Avatar
Will Russell Will Russell is offline
running a 12 core 5,1 with Mojave. Stable and steady.
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.6, PT2021.6, HDX, D-Command
Retina 5k iMac OS 10.15.6, PT2021.6, BabyFacePro FS
Retina MacBook Pro OS 11.4, PT2021.6
Old 09-15-2021, 04:46 PM
Originally Posted by DetroitT View Post
2010 5,1 HDX, 64gb
Ultimate 2021.7
Rx580 flashed
Running well.
A bit off-topic: I have the RX580 as well, but not flashed (so no boot screen). Did you buy it flashed or is there somewhere online that walks you through how to do it?
Old 09-16-2021, 03:59 PM
DetroitT's Avatar
http://www.macvidcards.com
http://www.macvidcards.com/store/p82..._Services.html
Old 09-17-2021, 02:38 AM
Farhoof's Avatar
Farhoof Farhoof is offline
All our suites are running 5.1 mac pro's, high sierra, pt2019.6, hdx2 and with specific RX570 cards that require only 1 power cable. By now we are pushing them to the max but we'd rather not invest into Intel macs anymore.
Next step is a new generation of M1 and switch to full native.
Old 09-17-2021, 09:53 AM
rodpost rodpost is offline
Still running a 5.1 Mac Pro 'cheese grater' 12 core, 128 ram
Mojave Mac OS ProTools Ultimate Latest Version
All works well, very stable
Old 09-17-2021, 10:49 AM
Only downside about old computer is you set it and forget it, no chance of updating ANYTHING. Sometimes it is a good thing too.
My old ones:
1)
2009 Mac Pro with 48GB ram and HD3|accel cards
2)
2004 PowerMac G5 with 8GB ram ad HD3 cards
3)
1999 PowerMac G4 with 2GB ram and MIX3 cards
All of them still in perfect working condition and seeing some use occasionally (live gigs and monitoring). Slow as hell compared to modern ones, but at that time best money could buy.
Nowadays need to be aware that the motherboard battery may run out any day and while that only seems to mess up the clock, it also messes up serial authorizations and need to be replaced.
Another thing to consider is the hard drive. if you do not fire it up every now and then, there WILL be a day when it dies when you power it on. Bearings need some movement. And obviously you need to have a clone of the hard drives in case they fail and need to restore. Old installers are pain to find. May also be hard to find a HDD that 1999 motherboard accepts, but that is another story. New Old Stock is easier to find than old installers.
Old 09-19-2021, 04:34 PM
I remember in the 1990s there was a neighborhood junk store that had plenty of old "non-working" Macs. Turns out every one I bought just had a dead motherboard clock battery and a few bucks fora new battery at Radio Shack did the trick. Was able to get some pretty good machines for next to nothing and learned my way around inside & out of those older Macs. :)
96k sessions on an older computer kirkbross General Discussion 0 07-24-2014 03:17 PM
updating older PT LE on older Mac skfdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2013 01:03 PM
Question about an older Mac Pro and possible older versions of Pro Tools HD wolfman_rob Pro Tools TDM Systems (Mac) 13 07-21-2013 01:29 AM
Can't get my older pro tools to open on my new computer. west chelsea Pro Tools M-Powered (Mac) 3 05-06-2007 03:29 PM
OSX on an older computer Soberphobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-01-2003 07:55 PM
