Old 03-28-2016, 08:54 PM
Intransit Intransit is offline
Default 12.5 was running great for 4 hours?
Can anyone think of why this could happen? I didn't change anything in those few hours. Fresh install 10.10.5... It was going great, the CPU looked more stable then all the sudden a crash and right back where I was with 12.4... Tempo changes throwing errors, video sync errors, the only difference the CPU isn't showing a giant spike after the tempo change, It still looks a bit more stable then 10.9.5 and 12.4
I saw someone mentioning replacing the prefs file every few hours but that sounds ridiculous.
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB
HD Native PCIe card /// OWC Mercury Helios 3S
PT 24.3.0
Old 03-28-2016, 09:57 PM
philip888's Avatar
philip888 philip888 is offline
Default Re: 12.5 was running great for 4 hours?
I assume you have done and use the suggested optimizations AVID suggets?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 03-28-2016, 10:05 PM
Of course. Been using PT since the Mix system days. Energy settings, Wi-Fi off, Firewire networking, File Vault off. Separate drives for everything, Same setup that has a drive with 11.3.1 and OSX10.8.5... The only difference is plugin versions and PT 12 and the OS X. Followed this to the letter: http://avid.force.com/pkb/articles/t...Optimize-10-10
PT 24.3.0
Old 03-28-2016, 10:59 PM
Becharax's Avatar
Becharax Becharax is offline
Well I installed 12.5 and barely had the time to work more than 10 minutes ... but I can say so far that 12.5 startup load times takes significant time when compared to its predecessors ... the slugginesh still exists .... and when I tried to create a project in the cloud the session was ridiculously slow .... any comments ??
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 03-28-2016, 11:03 PM
Ya, the session load time seems crazy long now. I'm on 10.10.5 wondering if 10.11.4 would make a difference. I'm growing very tired of all this. It's even jeopardizing my work at this point.
PT 24.3.0
Old 03-28-2016, 11:10 PM
Becharax's Avatar
Not the session only ... but Pro Tools loading time as a whole when it has to look for the plugins etc ....
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-28-2016, 11:13 PM
I'm still waiting for this session to open. 10 min. Has to be this cloud BS I'm not even using.
Old 03-28-2016, 11:17 PM
madselhoff madselhoff is offline
No problems here at all ... loading time is fine, no hiccups whatsoever .. 10.11.4 on an old Imac i3 .. import/export, multi tracking running smoothly..
Old 03-28-2016, 11:26 PM
Becharax's Avatar
Weird ....
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-28-2016, 11:31 PM
clausiii's Avatar
clausiii clausiii is offline
normal PT loading times here. Takes a little longer on first start re-scanning the plugins folder.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Pro Tools 9 Running Great! jimst57 Pro Tools 9 19 11-09-2010 04:59 AM
PTLE 8.03 Running Great! MarkH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-23-2009 08:46 PM
6.7 running great!!!!!!!!!!!!!! THANKS DIGI radioking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-28-2004 03:29 AM
New HD System running GREAT!!! Robby Hamilton Pro Tools TDM Systems (Mac) 12 08-31-2002 05:38 PM
Working great for hours, then DAE error-42 Corbin Supak Pro Tools TDM Systems (Mac) 4 11-14-1999 09:31 PM
