So, I have a DIGI 001 (w/ Pro Tools LE 6.0.1), Reason (version 3.1.2), and a G4 running OSX 10.2
I remember reading somewhere that I can rewire Reason with Pro Tools LE if I am running OSX, but I need some assistance accomplishing this task. Any help is much appreciated. Thanks. |
Try searching the forum, this process has been discussed in detail in the past.
You got me confused already - the latest Reason version is 2.5
http://www.propellerheads.se/ ...either that or Reason Adapted. If you search this forum you will find PT session-files ready to use (look in the PTLE Windows forum). If you get those you will not need so much instructions.
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
Why don't you just upgrade to the latest OSX and Pro Tools LE? It's simple enough and you will find Reason right there in your plug-ins ready to go. Worked great for me.
Still working on getting the internet connection ran down to the studio, but I will upgrade to the latest versions as soon as that happens. I expect it will solve the problem, because I don't see Reason/Rewire in any list of plug-ins right now. Thanks for taking the time to respond.
I'm running PTLE 6.1.2 with Reason 2.5 and when I first did the install I was able to run them both via ReWire. Tonight I tried for the second time again after a few months and the DigiReWire plug in cannot be selected in the inserts list within the mixer window of any PT session. The DigiReWire plugin IS in the correct plug ins folder, but for some reason it is not allowing me to select it from the inserts list in the mixer. All other plug ins within the plug in folder operate fine and can be added to any tracks (aux, mono, stereo). I've tried reinstalling PTLE 6.1, then the 6.1.2 update and still no change. Any suggestions are appreciated.
Thanks! |
![]() Quote:
I made that mistake, I was so pissed because it wouldn't work, then my dealer told me. You should be able to get the update disk for free from your digi dealer if you don't have a good internet connection for downloading the update. |
6.2.2 PTLE is the latest version. This is where you should be at.
DesertDude 1.25 Alu/1.5 ram/10.3.4 PTLE 6.4-002R-Live-Reason |
![]() Quote:
10.2.8
run 6.1.2, unless you have an Mbox. If you've got an Mbox avoid 6.1.2 like the black plague. 6.1 or 6.1.1 should be sufficent.
Sam Ejnes Mix Technician, Freelance Sound Editor/Re-recording Mixer samejnes.com | IMDb | Analog Jitter rMacBook Pro 2.2 gHz Core i7, 10.10.3 16 GB RAM MOTU 828mkII, PT 12.1 HD Axiom 61, 2xArtist Mix |
Rewiring Reason 4 into Pro Tools | halifaxer12 | Pro Tools M-Powered (Win) | 4 | 08-04-2010 11:17 PM |
Rewiring Reason 4 into Pro Tools | halifaxer12 | Pro Tools SE and Essential (Win) | 0 | 07-31-2010 09:25 PM |
Rewiring Reason 3.0 Into Pro Tools 6.8 M-Powered | bunderson | Pro Tools M-Powered (Win) | 2 | 09-26-2007 09:25 PM |
I'm fumbling with Rewiring Reason and Pro-tools | grinninsimian | MIDI | 1 | 10-10-2006 08:23 AM |
Rewiring Reason into Pro Tools! | zErOcOoL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-03-2004 01:58 PM |
