PT9 HD - Can anyone confirm Auth/Ilok PT8 license?
Still need to run 8 so just wondering on the ILOK asset front what appears and disappears from there. Previously you've given up licenses on upgrades. so.
do you get a PT9 auth and keep 8? do you get a PT9 backup auth (2nd authorisation) thanks all..... |
Re: PT9 HD - Can anyone confirm Auth/Ilok PT8 license?
I had to surrender my PT8 licence when I crossgraded to PT9.
I assume if you buy the full version you can keep both... ? Assumption is the mother of all f*ckups though! Steve.
http://www.stormzone.tv |
So if I upgrade to 9 I cannot use the old version anymore and my tracking-ws (2xG5) is getting useless ? That sucks...
[Macbook Pro 15" C2D, Pro Tools 9.0.5, M-Audio Profire 2626, Terratec EWS Mic8] - [Mac Pro Quad-Nehalem, Pro Tools M-Powered 9.0.5, M-Audio Firewire Solo, M-Audio Oxygen 49] |
I would imagine the ilok 9 auth will also auth pro tools 8 S**t will hit the fan if it doesn't Chris
Steve, did you get a backup licence in your ilok account as well (ie one you can move to a second ilok)? Has anyone tried running 8 with the 9 authorisation yet (i'm guessing this won't go as previously this hasn't been the case)
Re: PT9 HD - Can anyone confirm Auth/Ilok PT8 license? edit: SOME INFO . .
Here's some info after I took the plunge
Ordered HD9 upgrade - uk 293£ completed checkout then asked for ilok id and core card serial - make sure you get this right as otherwise no dice! INTERESTING BIT - if you have multiple old HD licenses you get a choice which to redeem for the upgrade - goodbye PT 7 license! go to ILOK see it says surrender PT7 under details go to transfer on main studio ilok - oh dear, its says Digidesign 8HD Will be queued since another license with greater weight is in the way. Looks like it removes 8 and replaces it with 8 in the pt9 bundle (there are 2 pt9 licenses and one HD8 - presumably one is the HD element?) - anyway you can't move one license separately to another ilok so you are only getting the one auth here. I've moved it onto a clean ilok, i don't want to risk anything mid session with 8 i'm running Now to try it out..... |
I just ordered the HD upgrade by mistake. I don't want to get that yet. Hope they can cancel the order.
I wanted to upgrade the LE 7.3 version instead. Question is, if I ONLY update the LE 7.3, will the same license also work on the HD? |
So does 9 include a backup license for iLok or not? I'm guessing no?
And if 7 or 8 came with a backup license, does upgrading to 9 take back just one of those licenses (meaning you could have it remove an 8 authorization but still have an 8 authorization remaining on a different iLok)? |
It must somehow leave you with the ability to run previous version of PT, either PT9 will also auth PT 8 or it will allow you to keep one PT8 or PT7 auth on your ilok. Would be good to know exactly!!! chris
So anyone know if upgrading to 9 takes the 8 backup as well or if it's possible to keep an 8 intact?
um, quick, dumb Q: Does PT9HD require ilok license auth? | kindkind | Pro Tools TDM Systems (Mac) | 2 | 06-21-2012 06:13 PM |
Plugin auth weirdness - guest iLok prevents internal iLok? | Scott Helmke | VENUE Live Sound Systems | 3 | 09-07-2011 07:06 AM |
Transfer iLok auth. from old iLok to new 003 factory iLok? | lamp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-20-2007 07:05 PM |
ilok auth backwards compatibile - PT7.3 auth run 7.2? | Barnaby Bristol | Post - Surround - Video | 2 | 06-20-2007 09:30 AM |
Amp farm 3 ilok auth. "AMP FARM TDM HD"? confirm! | crizdee | Pro Tools TDM Systems (Mac) | 1 | 11-19-2005 10:06 AM |
