PT 7.3.1:
Symptom: When you try to drag a sound-file from the workspace onto a track that contains locked regions PT refuses to place the clip onto the track even when they donīt overlap. Steps to reproduce: -put a region onto a track. -lock the region -drag a sound from the workspace to the same track but before or behind the locked clip - PT will tell you that "the command cannot be performed because it would affect regions that are locked" even if they do not overlap. annoying work-around: first unlock the preceding region on the track before dragging. please fix! Frank.
PTHDn 2022.6 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron |
I can't reproduce this given the steps you provided.
Can you give more info on the type of session - .bwf? .aiff? Are the regions part of the same audio file? Any other info that may be relevant is appreciated. |
In my case the source is an interleaved stereo AIFF sitting on my Desktop. Iīm option-dragging to 2 mono-tracks. I can see the placeholder region when I drag but when I let go of the mouse the message comes up.
When I unlock the region on the track wich doesnīt belong to the file Iīm trying to add it works fine. Session-Format is AIFF 24bit TC25fps PT 7.3.1 OSX10.4.8 G5 dual 2.5Ghz Session is on an internal SATA-drive. Deleting the databases didnīt help. thanks, frank. EDIT: I just tried it with a new empty session and it didnīt show the problem. Weird. Maybe something else that might be the problem? I cvan send you the session if you give me an adress. EDIT #2: So now I went back to the original session and it didnīt happen anymore. Crazy. It happened every day during the last week and now that I reported the problem it went away. Great.
Thank you for that - I can reproduce this now and will have it looked into.
![]() Quote:
So now it happens on your side but not here anymore. Thanks for listening. Frank.
PT 11.1.2 - Drag from workspace | willeyh | Pro Tools 11 | 3 | 02-03-2014 04:50 PM |
drag from workspace is very slow | breakie | Pro Tools TDM Systems (Win) | 0 | 11-20-2006 03:07 PM |
Drag & Drop locked regions bug (crosspost) | Dan Pinder | Post - Surround - Video | 0 | 10-01-2006 06:59 PM |
drag & drop and locked regions bug | Dan Pinder | Pro Tools TDM Systems (Mac) | 1 | 09-29-2006 12:10 PM |
PT Workspace: Drive LOCKED to "T"; not "R" | Chris Nelson | Pro Tools TDM Systems (Mac) | 9 | 10-06-2005 02:12 PM |
