#611
Re: Problems with PTLE? Post your configuration he
hmmm... i thought you might say that. unfortunatley that is not an option, as my non-system drive came from my previous computer, and requires a different style cable to the newer drive.
#612
I just fired up PT7cs4 on my brand new machine, all excited to get started again, and I have no audio out and choppy meter animation. The machine was supposed to have been optimized for PT by the manufacturer (a DAW specialty shop).
I've been DAWless for a month and a half after having been robbed and I will be devastated if I have to send this thing back. Please help! Processor Model : 1x AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ Speed : 2.20GHz Model Number : 4400 (estimated) Performance Rating : PR6600 (estimated) Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 2x 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA AGP PCI PCIe IMB CardBus USB FireWire/1394 i2c/SMBus MP Support : 2 Processor(s) MP APIC : Yes System BIOS : AT/AT COMPATIBLE Total Memory : 2GB DDR-SDRAM Chipset 1 Model : Clevo/Kapok Computer K8T890 CPU to PCI Bridge Front Side Bus Speed : 2x 1000MHz (2000MHz data rate) Chipset 2 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1000MHz (2000MHz data rate) Total Memory : 2GB DDR-SDRAM Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce Go 7800 GTX Imaging Device : USB2.0 1.3M PC CAM Physical Storage Devices Hard Disk : HTS721060G9AT00 (56GB) Hard Disk : WDC FireWire/USB2.0 IEEE 1394 SBP2 Device Hard Disk : GENERIC USB Storage-CFC USB Device Hard Disk : GENERIC USB Storage-MSC USB Device Hard Disk : GENERIC USB Storage-SDC USB Device Hard Disk : GENERIC USB Storage-SMC USB Device CD-ROM/DVD : PIONEER DVD-RW DVR-K16 Logical Storage Devices Os (C:) : 55GB (45GB, 82% Free Space) (NTFS) 051114_1117 (D:) : 125MB (UDF) Removable Drive (E:) : N/A Removable Drive (F:) : N/A Removable Drive (G:) : N/A Removable Drive (H:) : N/A Wdc combo (I:) : 233GB (130GB, 56% Free Space) (FAT32) Peripherals Serial/Parallel Port(s) : 2 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA USB Enhanced Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Texas Instruments PCI-1410 CardBus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Synaptics PS/2 Port TouchPad Mouse : Logitech USB TrackMan Wheel Human Interface : USB Human Interface Device MultiMedia Device(s) Device : Realtek AC'97 Audio for VIA (R) Audio Controller Communication Device(s) Device : AC97 Soft Data Fax Modem with SmartCP Power Management AC Line Status : On-Line Battery No 1 : 100% Operating System(s) Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Adapter : Realtek RTL8169/8110 Family Gigabit Ethernet NIC Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
#613
Re: Problems with PTLE? Post your configuration here..
Same sob story as always. Constant 9129 errors, but only after the first play. The first time works fine. Then it goes batty, especially when theres more plugins involved. I'm using 6.7 w/ an MBOX. HP laptop. I've had this problem for a year now but dealt with it. Now I am working on an album and it's getting embarassing..... coming to a complete standstill. My PC should be able to handle this, right? Oh yeah, I've done EVERYTHING. Every little tip i've found on here and in the manuals. Well, I only got to page 8 on here before my eyes were bleeding. Diagnostic Mode, Battery thing disabled, network cards disabled, folders deleted. all sorts of things with absolutely NO improvement. HELP!!! I am ready to jump ship!!!
SiSoftware Sandra System Host Name : OWNER-NMYQSCN1X User : Owner Domain : MSHOME Processor Model : 1x Intel(R) Pentium(R) 4 CPU 3.20GHz Speed : 3.20GHz Performance Rating : PR4256 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 2 Unit(s) Internal Data Cache : 8kB Synchronous, Write-Thru, 4-way set, 64 byte line size L2 On-board Cache : 512kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector Mainboard Bus(es) : ISA AGP PCI IMB CardBus USB i2c/SMBus MP Support : 2 Processor(s) MP APIC : Yes System BIOS : AT/AT COMPATIBLE PTLTD - 6040000 Total Memory : 1.1GB DDR-SDRAM Chipset 1 Model : ATI Technologies Inc Radeon IGP9100 Host Bridge Front Side Bus Speed : 4x 200MHz (800MHz data rate) Total Memory : 1.3GB DDR-SDRAM Shared Memory : 4294967295GB Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : ATI MOBILITY RADEON 9000/9100 IGP Physical Storage Devices Hard Disk : ST9100824A (93GB) CD-ROM/DVD : HL-DT-ST DVD-RW GWA-4080N (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr) Logical Storage Devices Hard Disk (C:) : 93GB (63GB, 67% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : NEC PCI to USB Open Host Controller USB Controller/Hub : NEC PCI to USB Open Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub PCMCIA/CardBus Controller : Texas Instruments PCI-1520 CardBus Controller PCMCIA/CardBus Controller : Texas Instruments PCI-1520 CardBus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Alps Pointing-device MultiMedia Device(s) Device : SoundMAX Integrated Digital Audio Communication Device(s) Device : Agere Systems AC'97 Modem Printers and Faxes Model : hp psc 1310 series Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Adapter : Broadcom 802.11b/g WLAN |
#614
OK. After a little more reading.... Am I understanding correctly that my BRAND NEW 100GB Hard Drive is unacceptable because it is only running at 5400 rp??? BUT that I shouldn't be running PT directly to my hard drive anyway???............ (huff, huff) ok. So what I need to do is get a Firewire adapter (because protools doesn't like USB 2.0, right?) and an external firewire drive running at 7200 rpm, and move all the session and audio files to THAT? Should I be good then???? judging by quick research this is gonna cost me about $250. does that sound right?
#615
#616
OK. I went out last night and got a firewire card and 160gb hard drive for only $150. But so far I haven't gotten everything working correctly........
#617
Can you tell me what your chipset is?
#618
this is from the sandra thing:
Chipset 1 Model : ATI Technologies Inc Radeon IGP9100 Host Bridge Front Side Bus Speed : 4x 200MHz (800MHz data rate) Total Memory : 1.3GB DDR-SDRAM Shared Memory : 4294967295GB |
#619
Greetings all,
First of all thanks for all the information you guys give in these forums. Pro Tools can be a frustraiting at times. Without these forums i would have most likely put my head through the monitor on several occations. ok,,, first of all i had protools 6.4 on a sony with a intel 3.0 with 1 gig of ram and no extra hard drive ran everything on the system 7200rpm drive that came with it and everything ran great up to 12 tracks.which was fine for me.and i didnt disable anything...except for hyperthreading ....im no pro...just do it as a hobby. so i built a new computer that i thought would handle pro tools better. i thought i read up enough to think that a dual core would work better..i have 2 hard drives a 10000 rpm that i use for my system and a 7200 i use just for storage..no programs operate off of it..i have my sessions stored there with the audio files and everything. Well.. i found out 6.4 doesent work well with my dual core so i upgraded to 7.0...and the patch...and i get constant buffer sizer errors..and system held off errors..with only 2 tracks...i cant imagine why this is..i have double the ram...more processing power...ive tried diffrent playback buffer settings...from one processer to two....two seems to work a little better but i still only get 4 tracks and bam...errors out the ying yang..i was hoping one of you gurus could help me out...before i break something of value thanks SiSoftware Sandra System Host Name : CHRIS-8DA5670A3 User : Chris Domain : WORKGROUP Processor Model : 1x AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ Speed : 2.01GHz Model Number : 3800 (estimated) Performance Rating : PR6028 (estimated) Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 2x 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA PCI PCIe USB FireWire/1394 i2c/SMBus MP Support : 2 Processor(s) MP APIC : No System BIOS : Phoenix Technologies, LTD 6.00 PG Mainboard : http://www.abit.com.tw/ KN8 SLI(NF-CK804) Total Memory : 2GB DDR-SDRAM Chipset 1 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1005MHz (2010MHz data rate) Total Memory : 2GB DDR-SDRAM Memory Bus Speed : 2x 200MHz (400MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 7800 GT Physical Storage Devices Hard Disk : WDC WD2500KS-00MJB0 (233GB) Hard Disk : WDC WD740GD-00FLC0 (69GB) CD-ROM/DVD : HL-DT-ST DVDRAM GSA-4167B (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) CD-ROM/DVD : HL-DT-ST DVDRAM GSA-4167B (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) CD-ROM/DVD : SCSIVAX DVD/CD-ROM SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd) Logical Storage Devices Hard Disk (C:) : 69GB (43GB, 61% Free Space) (NTFS) Bf2 cd 1 (D:) : 700MB (CDFS) swap file (E:) : 4.9GB (876MB, 18% Free Space) (NTFS) Storage (F:) : 228GB (210GB, 92% Free Space) (NTFS) CD-ROM/DVD (G:) : N/A CD-ROM/DVD (H:) : N/A Peripherals USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Keyboard : HID Keyboard Device Mouse : Logitech-compatible Mouse PS/2 Human Interface : HID-compliant consumer control device Human Interface : HID-compliant game controller Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device MultiMedia Device(s) Device : Realtek AC'97 Audio Printers and Faxes Model : Microsoft Office Document Image Writer Model : HP DeskJet 810C Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Adapter : CNet PRO200 PCI Fast Ethernet Adapter |
#620
I noticed my ram is running at 333mhz should i go into the bios and change it from auto to 400? or is there a reason its only running at 333? here is my sisandra info
< Processor > Model: AMD Athlon(tm) 64 X2 Dual Core Processor 4800+ Speed: 2.41GHz Model Number: 4800 (estimated) Performance Rating: PR7236 (estimated) Cores per Processor: 2 Unit(s) Threads per Core: 1 Unit(s) Type: Dual-Core Internal Data Cache: 2x 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache: 2x 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size < Mainboard > Bus(es): PCI PCIe USB FireWire/1394 i2c/SMBus MP Support: 1 Processor(s) MP APIC: No System BIOS: Phoenix Technologies, LTD ASUS A8N-SLI Premium ACPI BIOS Revision 1011-001 System: System manufacturer System Product Name Mainboard: ASUSTeK Computer INC. A8N-SLI Premium Total Memory: 2GB DDR-SDRAM < Chipset 1 > Model: Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed: 2x 1005MHz (2010MHz data rate) Total Memory: 2GB DDR-SDRAM Memory Bus Speed: 2x 160MHz (320MHz data rate) < Video System > Monitor/Panel: Plug and Play Monitor Adapter: Diamond X700-PCIE 256MB Adapter: Diamond X700-PCIE 256MB - Secondary < Physical Storage Devices > Removable Drive: Floppy disk drive Hard Disk: WDC WD1200JB-22GVA0 (112GB) Hard Disk: WDC WD800JB-00JJC0 (75GB) CD-ROM/DVD: JLMS XJ-HD166S CD-ROM/DVD: PIONEER DVD-RW DVR-110D < Logical Storage Devices > 1.44MB 3.5" (A:): N/A Hard Disk (C:): 75GB (65GB, 87% Free Space) (NTFS) Drv2_vol1 (D:): 112GB (48GB, 43% Free Space) (NTFS) Audio cd (E:): 0 byte(s) (CDFS) CD-ROM/DVD (F:): N/A < Peripherals > Serial/Parallel Port(s): 1 COM / 1 LPT USB Controller/Hub: Standard OpenHCD USB Host Controller USB Controller/Hub: Standard Enhanced PCI to USB Host Controller USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub FireWire/1394 Controller/Hub: Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard: Standard 101/102-Key or Microsoft Natural PS/ 2 Keyboard Mouse: HID-compliant mouse Human Interface: HID-compliant consumer control device Human Interface: USB Human Interface Device < MultiMedia Device(s) > Device: MPU-401 Compatible MIDI Device Device: Standard Game Port < Printers and Faxes > Model: Canon Bubble-Jet BJC-250 < Power Management > AC Line Status: On-Line < Operating System(s) > Windows System: Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2) < Network Services > Adapter: Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller < Performance Tips > Warning 100: Large memory sizes should be made of Registered/Buffered memory. Tip 2546: Large memory modules should be ECC/Parity. Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip.
i7 920, Gigabye ud4p, 12gb OCZ Platinum ddr3 1600, 2x 640gb WD Caviar Black 1x Samsung 120gb SSD
HACKINTOSH Mac OSX 10.8 Pro Tools 10.2 OLD Dverb 1024 - 520 Dverbs 64 - 433 Dverbs NEW Dverb 1024 - 283 64 - 235 |
Problems with PTLE? Post your configuration here...... | still_life_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-30-2007 12:27 AM |
Problems with PTLE? Post your configuration here.. | DJ John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2007 10:06 AM |
Problems with PTLE? Post your configuration he | krsongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-28-2007 09:59 AM |
Problems with PTLE? Post your configuration here.. | p3tch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-28-2007 09:46 AM |
Problems with PTLE? Post your configuration here.. | Gaba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-23-2007 08:01 AM |
