Pro Tools First does not load
ProTools First worked perfectly until a week ago when it didn't start, it crashed when reading the plugins.
I have reinstalled the software 2 times and it doesn't work. Please I need help I would be very grateful. Thanks |
Re: Pro Tools First does not load
Are you using the plugins that came with Pro Tools First only or have you installed additional plugins?
You can try removing the plugins from the plugin folder one by one to see which is hanging Pro Tools. Do not delete them, just move them to a different folder on your system and restart PT. |
I already did, and unfortunately it still doesn't work.
Checking the avid page, it says that ProToolsFirst is discontinued. Ok, but what about my projects? How can I do to export them to wav and reuse them? Thanks |
Your signature lists macOS Sierra which wasn't qualified for v2021.6 (though you said it was working previously). I'd suggest trashing InstalledAAXPlugIns which will get recreated on launch. Find this in: /Users/*username*/Library/Preferences/Avid/Pro Tools First
• linkedin •
Thank you very much Jeffro
I must add that, due to lack of disk space, I need another address to an external disk for the PTFirst Projects. Please, how can I do? Thank you again in advance for your attention, I await your instructions :) |
Before moving further, are these offline local projects? or Cloud projects? Unfortunately, moving Pro Tools First's cache folder will cause issues to your projects. I suggest installing the trial version of Pro Tools Ultimate or Pro Tools Intro, then sign in using the same Email account used in PTFirst. Just a note that Pro Tools Intro is limited to 8 tracks, so tracks beyond the limit will be deleted. Thanks, Tope |
hello Tope:
The projects are local and now some I can't open them, I get a warning "Your request could not be completed because it is not the correct document type (-20006)". It should be said that the PT Intro does not read First Projects. How could you help me? Thank you so much in advance for your attention Juan Carlos |
Pro Tools will not load | Keniko | Pro Tools 2020 | 2 | 11-02-2020 11:43 AM |
Pro Tools 11 Won't Load | Verses | Windows | 2 | 08-26-2017 09:26 AM |
Pro Tools could not load the following.. | daverose | Pro Tools 10 | 8 | 09-21-2015 01:39 PM |
Pro Tools 10 not load plugins,freezing load.HELP | javierboz | Windows | 2 | 11-08-2012 04:25 AM |
Pro Tools 8 LE won't load | SoundQuarters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-28-2010 04:07 AM |
