Old 02-05-2021, 10:37 AM
Brandonx1 Brandonx1 is offline
Default expand faders quick question
Hi All,
I just replaced my MTM. So I'm starting from scratch, probably for the best. I am stuck on one issue. I can't seem to get the expand fader module to work as is used to. I used to have it set to expand insert 4, which is dns 1. I have that selected in the settings and I have auto expand faders in the user settings. I think that's all I did years ago to get it to automatically expand the attn channel. What I'm I missing. I can not get anything to attn on my fader expand zone now. The faders jump all the way down like they are waiting for me to attn a track but nothing happens when I do. Little help please.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 02-05-2021, 11:26 AM
creativecontrol's Avatar
Default Re: expand faders quick question
Greetings!
Here are a few things to try:
Make sure that whatever expand fader map you are trying to access first is accessible in a local expand from standard channel strips:
Navigate to the function - or insert parameters page for a plug-in then press Exp. If you have Settings > User > Auto Expand Faders disabled, then you will have to hold down Exp for a few seconds to bring up the Expand Faders in addition to the Expand Knobs.
If you need to recreate your maps, use Attention + Exp from the strip containing the function you want to program.
Once you have determined that the local expand fader is good for your function, enable the Attention Expand Fader Zone - either from the (Extras) Soft Keys or from the Home > Local Options > Enable Attention Expand Fader Zone.
From there -> on the same Local Options page of Home, configure Expand Fader Function to set the target for what you want to populate there on attention. Let me know how it goes!
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-05-2021, 01:56 PM
Originally Posted by creativecontrol View Post
Greetings!
Jeff
Yes that works. I can see the Cedar on the knob expanded
The have expand faders enabled in the user session. When I do this the expand button turns while really light blue it that what should be happening?
This makes the expand button white or light blue still. No flashing knobs to program I'm stuck here.
Not good.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 02-05-2021, 02:54 PM
Is Auto Expand enabled under Settings > Users?
And is the Triangle with the Faders Soft Key at the bottom of Extras White or Purple?
Also - please indicate S6 and Pro Tools software versions.
The whole enchilada is here:
http://duc.avid.com/showpost.php?p=2...&postcount=144
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-09-2021, 11:46 AM
Hi Jeff,
The triangle is purple.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 02-09-2021, 11:59 AM
Thanks. From your description:Yes that works. I can see the Cedar on the knob expanded.
It doesn't sound like you have a map defined. If you had a map defined and you pressed Exp (even from a local fader bank) you would see faders populated with parameters. Scan through the video I posted and let me know if you still have questions.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-08-2021, 07:20 PM
indeloon85 indeloon85 is offline
Wondering if this ever got resolved. I'm having the same issue with the S6 not wanting to Expand knobs to faders. I've checked preferences but completely at a loss after checking manual and watching videos in case I forgot how to do it but it doesn't function as it should
Old 09-09-2021, 06:19 AM
Greetings,
Are you running EUCON version 21.6 or later? If so, your existing Expand Fader maps will need to be recreated - from the Master Module by first Attentioning the function (Insert > Parameters for example) then touching the Fader Module (illuminates in purple) to designate the section to map.
If you are using a dedicated On Attention Expand Fader zone - ensure a few things:
The Expand Fader Zone is not suspended.
If the On Attention Function is set to "Inserts Any" - make sure the Inserts chain is not collapsed on the function scroller.
Let us know what you find.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-09-2021, 07:21 AM
Yes I got it sorted. For me it was a networking issue. I had my dante network switch and my internet network switch for some reason with the same network gateway. I changed the network gateway on my dante switch to a non internet network address and everything worked 100%.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Automation and faders.. Quick question realizment Windows 2 10-12-2014 12:57 AM
Non touch sensitive faders quick fix before I contact Digi? macaholic ICON & C|24 4 06-24-2009 08:54 AM
Quick Q bout faders??? digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-11-2006 06:15 PM
quick way to lower faders? chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-11-2006 07:40 PM
Quick quick quick DSP farm card Question Mr335 Pro Tools TDM Systems (Mac) 1 12-06-2002 07:37 AM
