Old 11-08-2004, 06:47 PM
fmbighair fmbighair is offline
Default headphone output on Powerbook sounds mono?
I am just wondering if anyone on here has a 12 inch powerbook?...on mine, when I use headphones to listen to a song (cd, mp3, internet, etc) one side sounds good and the other side is at a really low vollume (barely on).....so it almost sounds mono....
so it's really annoying when I'm listening with headphones....I tried different headphones and it still does the same thing.....
The manual says that the headphone output is stereo but the left and right levels are clearly not equal; is there a setting I can change in the powerbook that I can adjust the left and right balance?....
this is driving me nuts , any help would be appreciated, thanks
Old 11-08-2004, 07:07 PM
Slim Shady Slim Shady is offline
Default Re: headphone output on Powerbook sounds mono?
You can try your sound preferences under system preferences and make sure your output is panned to center. If that doesn't solve it, then you probably have a defective headphone jack perhaps with just a bad connection or something, and you should head over to your nearest apple reseller to have them check it out.
Old 11-08-2004, 08:00 PM
lexicon5 lexicon5 is offline
The defective jack is more likely the cause...
If you visit the Apple Support Forums, under PowerBook, you'll see a lot of this...
It's such a fine line between stupid, and clever. -David St. Hubbins
Old 11-12-2004, 09:12 PM
Lexicon5 YOU ROCK!!!......You were exactly right!.....I have never been to the system preferences; so for some strange reason, it was defaulted from the factory as panned to the right?...I have never head of such a thing?.....
thanks again
Old 11-12-2004, 09:14 PM
oops...Slim Shady was the one with the right answer....lol.....Thanks Slim!!!! You also rock.....
I'm really glad that the jack was not defective...
No headphone jack output - Meters showing output Hotcrazyfruit Eleven Rack 6 05-06-2012 01:09 PM
Headphone output only mono Tony-N Eleven Rack 2 01-26-2012 04:31 PM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 06:10 PM
M-Box 2 Headphone output sounds crappy is it my headphones? 2-Tone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-22-2009 02:32 PM
DIGI001 headphone output mono..? Sabe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-08-2003 07:24 PM
