Old 12-04-2010, 05:08 PM
ETfromNJ ETfromNJ is offline
Default PT Aggregate I/O problem for Digi 96 I/O hardware
I just upgraded to PT 9, and was excited to be able to use some extra firewire I/O's that I have...Duet, etc.....only to find out from the tech at my gear supplier that Digi (tech support) told him that the Digi 96 I/O's will NOT work with any other digital devices in the Aggregate mode at this time What?! I would have found out directly from Avid/Digidesign but you can no longer actually call them up, I guess, unless I'm missing something. My store tech apparently can talk to someone at Avid, and that what they told him...Is there anyone else trying to run 96 I/O's with PT 9 in Aggregate with other hardware? And, if there is really no work-around, does anyone know what Digi is going to do about it? And when?
Sorry, but this very disappointing...it's like Santa didn't come down my street or something...
Thanks
Old 12-04-2010, 05:14 PM
Craig F Craig F is offline
Default Re: PT Aggregate I/O problem for Digi 96 I/O hardware
HD does not play well with others, probably never will
Thank you,
Craig
Old 12-04-2010, 06:35 PM
Generally, people that use either the 96IO or the 192 IO are running HD and have the proper interface cable and cards in their system. I can't think of any good reason to bother with a 96IO on a system without HD cards(other than the obvious, "I have it" scenario). Check the air users blog for a comprehensive list of hardware that works well(and several that do not). The 96IO is not a very "high-grade" unit and there are many that WILL work, and will sound better in the process(the 96IO is on par with the 003).
[IMG] code is Off
PT Aggregate I/O, Playback engine / Hardware set-up question LSNY Pro Tools 9 2 01-30-2011 02:24 PM
Can You Aggregate With HD Hardware? edadema Pro Tools TDM Systems (Mac) 4 11-15-2010 08:15 PM
DIGI 002 Hardware Problem pinkyf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-27-2007 06:58 AM
No Aggregate device for Digi hardware? lwilliam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-11-2007 10:12 PM
DIGI 002, Problem installing hardware driver "cannot find hardware" on install inevitable realisation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 08-21-2003 02:03 AM
