Old 07-28-2021, 01:10 AM
simonchase simonchase is offline
Default Clip effects need jolting into life
Hi All,
Sometimes I do a slight tweak using a clip effect and nothing happens to the audio. For example I add a hint of top end but it doesn't kick in. So then I kind of waggle the node more violently and it kicks in after a second or two and I can put it back to the more gentle settings and it's now audible. If I use the same "channel strip" eq as a live plug-in on a track there's never a delay.
It makes me worry about it being reliably set. Anyone else?
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 07-28-2021, 03:48 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Clip effects need jolting into life
Yes, the first click doesn't do anything. After that all works fine. I've made it a habit to always make 2 clicks on the first parameter change.
Does it improve when you completely disable eucon?
Clip effects as a paid add-on lesbrunn Pro Tools 2020 22 08-04-2020 02:26 PM
Clip Effects SBP Pro Tools 12 1 06-12-2017 04:19 PM
Disable Clip Effects markuse_23 Pro Tools 12 0 01-31-2017 03:06 AM
Cannot Edit Clip Effects in PT 12.6 HD conleec Pro Tools 12 81 01-30-2017 07:55 PM
Clip Effects Freezing Carl Lie Pro Tools 12 3 10-05-2016 04:24 AM
