Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 03-10-2021, 02:22 PM
Drywsef Drywsef is offline
Default HDX Sidechain Delay Compensation Broken?
Hi all,
I stepped up to HDX somewhat recently in large part to take advantage of sidechain delay compensation. To my surprise, it doesn’t seem to work very well. I have the option checked in preferences, but I’m still getting audio arriving early/late to sidechain inputs when I monitor them. Is this feature only for DSP plugins? Has anyone else found any “rules” to using sidechain delay compensation properly?
Thanks in advance.
Win 11 23H2 - PTU 2024.10 - HDX - Blue 192 - Prism Titan
i9 10900K, Asus Tuf Gaming Z490 Plus, Corsair Vengeance LPX 32GB, NVIDIA 1070ti
OS/apps, sessions, and samples all on separate drives.
Old 03-10-2021, 06:48 PM
bolooki bolooki is offline
Default Re: HDX Sidechain Delay Compensation Broken?
wondering about this too!!
Can you test with both DSP/Native instances of the same plug-in to see if only AAX dsp's compensate a compressors key input properly?
maybe only Avid AAX DSP's do it? this isn't clear on any documentation...
Old 03-12-2021, 08:24 AM
JingleDjango JingleDjango is offline
I'm very curious to hear more details on this. Were you able to test it? Has anyone?
Old 03-16-2021, 05:15 PM
bump... can anyone try a test using the same DSP and non-dsp plugin?
Old 03-18-2021, 05:10 AM
mr xy mr xy is offline
Delay comp for side chains is indeed only for DSP plugs
Old 03-18-2021, 05:20 AM
midnightrambler midnightrambler is offline
Originally Posted by mr xy View Post
Delay comp for side chains is indeed only is only for DSP plugs
So basically what we're saying is AVID can't get it to work for native plugs regardless of architecture. *Slow hand clap*
Old 03-18-2021, 08:10 AM
My feeling is they absolutely could get it to work if they were motivated to do so.
The fact that it would be slightly more complicated than just adding the "feature" probably doesn't help it's chances of even being implemented.
They would have to add a preference to turn it on or off so as to keep compatibility with existing sessions which have side-chain delay accounted for manually.
I used to find it a real frustration but I've got so used to the workarounds I don't even care that much anymore. It is the exact sort of incremental improvement I was hoping to start seeing more often when they switched to a subscription model many moons ago.
There are so many small details which could be improved upon, I'd much rather a steady incremental development and refinement than flashy new features.
Commit and Sidechain Delay Compensation Glo123 Pro Tools 2020 0 01-10-2021 12:25 AM
Sidechain Delay Compensation JingleDjango Pro Tools 2020 6 06-17-2020 07:02 PM
Workaround for sidechain delay compensation? DJ Hellfire Pro Tools 12 8 07-15-2017 10:37 PM
Delay Compensation in 10.3.8 seems to be broken spiritfallrecording Pro Tools 10 6 01-19-2014 08:24 PM
Delay compensation broken jturner Pro Tools TDM Systems (Mac) 33 09-16-2009 04:55 PM
