Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-17-2020, 12:50 PM
JingleDjango JingleDjango is offline
Default Sidechain Delay Compensation
Will this ever get fixed or is it time to start switching DAWs?
Old 06-17-2020, 01:09 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Sidechain Delay Compensation
It has never been broken, but only available with HDX system
Janne
Old 06-17-2020, 01:30 PM
Downtown_BE Downtown_BE is offline
and HD native?
Old 06-17-2020, 01:32 PM
JFreak's Avatar
HDX only
Janne
Old 06-17-2020, 03:32 PM
If its causing issues for you, tell us in what way and someone might have a work-around to solve it(unless you need a good excuse to change DAW's)
Old 06-17-2020, 06:55 PM
bolooki bolooki is offline
the least they could do is implement a native delay calculator tool to allow for measurement and precise manual adjustments. I get that you can manually adjust delay per track, but it gets extremely confusing later in the mix when all I want is one plugin to hear the kick on time no matter what. Correct me if I'm wrong, but I thought I read that HDX delay comp is only with avid AAX plugins too. Plugins also just report incorrectly so it would be nice to be able to run a "SC delay comp check" to see if something is off. (I have this issue with UAD on aux channels a lot). HDX really sucks for tracking thru plugins and is not worth buying just for this.
If anyone has a proven way of discovering, measuring and compensating for side chain delay- please post.
Old 06-17-2020, 07:02 PM
unkJE's Avatar
unkJE unkJE is offline
Best Sidechain Delay Compensation (7-page) Thread I've read so far:
https://duc.avid.com/showthread.php?t=377469
As HD (HDX) features seem to trickle down to Vanilla, we may see this yet!
Aux Routing Weirdness / Ping-pong Delay Messes Up Delay Compensation MKZ Pro Tools 2018 3 02-10-2024 11:31 AM
Workaround for sidechain delay compensation? DJ Hellfire Pro Tools 12 8 07-15-2017 10:37 PM
Sidechain Compression Delay When Bounce to Audio Obe1 Pro Tools 11 6 07-23-2015 03:00 PM
PT11 - sidechain inputs not delay compensated on non-HDX systems mr xy Pro Tools 11 6 02-04-2015 01:25 PM
Please confirm/ deny: Sidechain inputs are not delay compensated in PT10? mr xy Pro Tools 10 17 02-04-2015 01:19 PM
