show plugin, when insert button pressed, anyone ?
I swear it worked before.
When I press An insert button on a channelstrip, EQ/DYN, I always have to press the plugin window button on the PC before the plugin pops up. Is there a way to show the plug immediately when you press insert button? |
Re: show plugin, when insert button pressed, anyone ?
Well, you do have to check to see if the PLUG-IN button is lit in the WINDOWS section. For some reason, sometimes that get's turned off, then those plugins won't pop up on the screen. That should be the problem.
Paul Dexter 7k' Productions 7kproductions.com |
What button have i pressed?? | blackbirdstudio | Pro Tools TDM Systems (Mac) | 8 | 05-17-2010 12:06 PM |
Delay When Record/Play Button Pressed | kaoticjackal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-25-2009 02:42 PM |
No insert Button, and no Mix knob on Mbox2 Pro? How on earth... | 11miles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-09-2009 06:13 AM |
Was drunk, pressed wrong button, can't get back to normal... | grubbgto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-16-2008 07:12 PM |
Pro Tools LE crashing when Play button is pressed? | smattsav | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-11-2004 12:31 PM |
