Old 08-17-2005, 06:31 PM
kingxrich23 kingxrich23 is offline
Default audio clock/clock source and sample rate problem
so i finally got a new mac to try one last ditch effort to see if my digi002rack is really broken or if it was my pc that was causing it before. this is probably unrelated to my problem but my digi002r stopped working so i thought it was my pc that was broken so i got a new mac mini to test it out on. just in case you need the info i have a mac mini 1.4 ghz and 1 gig ram and protools 6.9.2 digi002rack. basically i just upgraded to 6.9.2, everything installed fine. however whenever i press record or play the demo that comes with it (since i cant record anything new) i get this.
"Problem detected with audio clock. Check that your clock source and sample rate are correct."
I never got this problem before on my pc (when my protools was working). Is this something i have to fix inside the protools program or something that i need to fix within the mac audio specs? also what should be my correct clock source and sample rate since it says its incorrect? if anybody can tell me what is wrong or better yet the remedy to this problem i would greatly appreciate it. or maybe my digi002r was broken in the first place =(.
Old 08-17-2005, 06:34 PM
Default Re: audio clock/clock source and sample rate problem
Open the Session Setup Window and make sure your clock is set to Internal.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 08-18-2005, 12:49 PM
I did what you said and it was already set to internal. I'm still getting the same exact message, anyone else have any other suggestions?
Old 04-06-2010, 09:54 PM
goldenbear goldenbear is offline
Check out the program called Reaper.....
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 7 08-10-2021 02:17 PM
Problem detected with audio clock. Check clock source and sample rate are correct mongrel8686 Third Party Interfaces 11 08-01-2013 09:42 PM
Problem detected with audio clock. Check that your clock source and sample rate are c Solow1nonly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-06-2011 09:22 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 08:09 PM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 04:40 PM
