Midi connection causing stop command unresponsive
Hi, I have this problem is driving me crazy a bit, I have a protools 8.0.1 cs1 LE and 003 Rack, on Leopard ppc, and every time I plug a midi cable in, in this case being a minimoog voyger, the stop command just doesn't work propperly.
On some info on the web I 've found there is a problem with a midi function called "midi run status" on the moog voyager, so I disabled it. The problem improved a bit, but I discovered that no matter what, every time I plug a midi cable in the port, the stop command just doesn't work right, it takes like 7 seconds or so to stop. I hace removed preferences, repaired permissions and all...but it have not done a thing, I even took away pluggins to no avail. So, what can I do to solve this problem ? any hints will be more than welcomed and apreciated. warm reggards... Last edited by losrack; 04-28-2010 at 03:14 AM. Reason: syntax error |
D-Command unresponsive | DaleB | ICON & C|24 | 2 | 03-23-2013 02:51 AM |
D-Command/XMON connection to interface | DaleB | ICON & C|24 | 2 | 04-17-2011 12:20 PM |
MIDI Controller Unresponsive In Pro Tools, Help Please! :( | Rezzolution | MIDI | 0 | 10-08-2010 09:51 PM |
How do I insert midi note "stop" command. | jdellas | MIDI | 0 | 02-21-2006 09:55 PM |
6.1 bug: command period doesn't stop bounce | Zumwalt | Pro Tools TDM Systems (Mac) | 8 | 07-26-2003 11:57 AM |
