Vocal Booth
Up until now we have had to track vocals in a 25'x 25'x 8' room. We don't like the sound we're getting out of this room for vocals. It would be nice if we could raise the ceiling, but that really isn't an option. So we've decided to cut into the room and build a Vocal booth.
Basically we're not sure what the demension's should be. How big do we want this thing. We want to get a real intimate sound from that room. Any suggestions on the best way to get this done? Are there alternatives to a vocal booth that I haven't thought of? Thanks |
Re: Vocal Booth
If you are planning to spend the cash to put in a booth and don't need the separation during tracking, you might consider ASC's studio traps. They work great for surrounding a singer or instrument and let you use as much or as little of the space as you desire. They also sound great. Check them out at www.tubetrap.com.
Re: Vocal Booth
Where the hell do you stash those things when you dont need em, also they look like they can all fall over wrecking gtrs etc, are they stable on their feet? how do they react to drunk persons?!
Jules |
Re: Vocal Booth
I'm assuming you're doing vocal overdubs, not cutting with a live band, right? (that would indeed require a booth… and a completely different answer from this end…)
To get an intimate vocal in a large ambient room, I usually build a U-shaped "booth" from foam gobos (1' x 4' x 8' pieces) with the mic facing back into the U and the singer facing out of it. Or, you can drape packing blankets over elevated boom stands to create soft "walls" around the mic. Usually more room bleed comes into the sides of the mic than the front or back. Also some soft treatment to the ceiling just above the vocal area would help. (And Jules, the foam gobos make great beds for those drunk people… or exhausted engineers… to pass out!) Good luck! Warmest Regards, Brian |
Re: Vocal Booth
Thanks!
That's great info. Until we get the room built I'll try a couple of those ideas. We do want to be able to track Vocals at the same time as the band (in some cases) as well as be able to use it for tracking acoustic guitar with a band. Also be able to use it as an amp room to isolate guitar amps if need be. So, Brian, if you could give me the "completely different answer" concerning a booth that would be much appreciated. Thanks, Brad |
Re: Vocal Booth
Jules,
I just line the walls with them, or add them to the Attack Wall (mixing station). They don't have problems leaning from one side to the other, but the drunks usually knock them down. The good news is I had them Scotchgaurded... Steve |
Vocal Booth? | Bart HLH | General Discussion | 5 | 03-02-2007 05:48 PM |
Vocal Booth | Mr.BossPlaya | Tips & Tricks | 4 | 07-04-2006 08:33 AM |
how to build a vocal booth? | wreckthisplace | General Discussion | 1 | 12-12-2005 10:28 AM |
homemade vocal booth | optymusblu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-24-2003 06:16 PM |
Vocal booth | SKI | Pro Tools TDM Systems (Mac) | 7 | 03-23-2003 12:05 AM |
