Audiosuite not processing
I just finished a project last night and wanted to apply Audiosuite processing to a couple of areas of the vocal track.
1. Selected the area 2. Opened Audiosuite and applied the effects as I wanted it. 3. Processed it 4. Computer showed processing taking affect After that it was just like the original. I tried about 10 different plugins just to test it (Waves and Digi) with the same results. Worked great in the past. Anything obvious that I'm doing wrong here? Thanks. Allen [img]images/icons/smile.gif[/img] |
Re: Audiosuite not processing
you sure you had a region selected? sometimes with audiosuite, if you make a change and don't hit enter after changing a variable, then hit process, the region will become unselected..... (that happened to me once - drove me nuts....)
i love my apple iPhone! |
there's an option in most AS stuff in the top right corner that allows you to select "Use In Playlist" and another option that i can't remember. make sure it is set to "Use In Playlist".
Brian,
You said hit enter after changing a variable. If I'm in Pitch Shift, where do you hit enter? Thanks. Allen [img]images/icons/smile.gif[/img] |
Matt,
That did it. Thanks for the help. Allen [img]images/icons/smile.gif[/img] |
Audiosuite processing | Reckah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-25-2009 02:20 PM |
Processing in Audiosuite (Yet another PT8 Bug!)... | Pony Slaystation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-14-2009 02:57 AM |
AudioSuite not processing | samvanhallgren | Pro Tools TDM Systems (Mac) | 2 | 03-10-2008 01:17 PM |
Audiosuite Not Processing | Lonnie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-27-2004 09:16 PM |
AudioSuite NOT processing | Abomb97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-09-2004 01:10 PM |
