Old 08-09-2022, 04:39 AM
BoRiZ KukoBa BoRiZ KukoBa is offline
Default One masterbus mix vs Multi masterbus
Hi.
I've been working with Pro Tools HD (MixCube, HD, Ultimate, Flex) for about 20 years now.
I want to ask the respected community about the details of mixing with HDX cards.
I did some simple experiments and found out that there is a significant difference in the transparency of the mix if you output tracks not to one master bus, but to as many masterbuses as possible.
At the same time, I send all these buses to the same physical output in the I/O settings.
I have a regular HD Omni interface and don't have an any analog summing device.
Why such a difference in sound? Is there a technical reason for this? Or maybe it seemed to me?
.:UPD:.
GO TO TEST RESULT
Thank you.
Pro Tools 2018.4 Ultimate; Omni HD+HDX1 over Thunderbolt 2; MacPro 6.1
Old 08-09-2022, 06:15 AM
climber climber is offline
Default Re: One masterbus mix vs Multi masterbus
Originally Posted by BoRiZ KukoBa View Post
Hi.
really? "..as many as possible..."?
Al Hospers
bass, vocal, composer, engineer
CleverSounds Recording
OS X Big Sur, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio , PT2021.12, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 08-10-2022, 12:58 AM
Ok, I understand your sarcasm. I understand that this is kind of crazy.
But I purposefully did this test dozens of times and every time I get same result.
I was wondering if someone had done similar experiments and someone had similar impressions/results.
Sorry if I distracted the attention of the community with this nonsense)
PS. I know people from among those who were involved in the development of the HDX engine. (The HDX card and part of the Pro Tools code was developed in Kyiv, Ukraine).
They opined that the card's mixer was bad at correcting errors. When many signals arrive on the same bus, the errors add up, which can adds "muddy" to the sound.
Old 08-10-2022, 08:35 AM
have you output them both ways and then seen if they null?
Al Hospers
Old 08-10-2022, 09:46 AM
JFreak's Avatar
JFreak JFreak is online now
The idea is not to get them null. Idea is to have more tuning options with ME on the final critical listening phase.
Say you have drum kit buss, solo bass track, guitar buss, misc buss, vocals buss and solo lead vocal track, that would all then again routed to your monitoring outputs. Just an example. When you bounce all of them and import to a new mastering session, you for example have easy possibilities to fine tune bass track levels without affecting anything else.
Then again, even if you trust your ME and want to experiment, also remember to bounce your monitoring outputs, a.k.a. your 2-track take on the song. When it is good it is good.
Janne
Old 08-10-2022, 11:37 PM
I haven't tried yet. Before that, I listened only subjectively.
I will try to make this test and post the result here.
Old 08-10-2022, 11:40 PM
Yes, and this is also one of the useful tip of this method.
Thank you for bringing this to our attention.
Old 08-11-2022, 01:05 AM
RamiHashash RamiHashash is offline
I have found the exact opposite to be the case for me.
When every track in the session is going out outputs 1-2 everything is as it should be.
As soon as I start bussing and routing through aux busses, it’s like the transients get smeared. Punch is gone and the stereo field seems narrower.
Also the case if there are any plugins on the Master Fader.
This is by no means fact. It could just be my brain messing with me.
Then again, I have been doing this a long time.
Rami
trs-studios.com
Old 08-11-2022, 02:59 AM
thin ice thin ice is offline
Would this happen on a Native system? Maybe you are separating different types of processing.
Mac Mini M1 16 GB
OS 12.5.1
PT 2022.7.0
Mac Pro Quad Core
OS 10.8
PT9HD
Old 08-11-2022, 06:02 AM
K Roche's Avatar
K Roche K Roche is offline
Hi.
Thank you.
Hum I am a bit confused so to clarify are you actually meaning Master Fader tracks as sub busses ? ---and what would the logistical difference be between multi Master Faders and a single Master Fader if they are going out a single stereo pair of main outs ???
System :
Avid Carbon interface , PT Ultimate 2022.6 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Monterey 12.5.1
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
HDX Masterbus Latency bertanica Pro Tools HDX & HD Native Systems (Mac) 9 02-01-2021 09:22 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Post - Surround - Video 0 06-08-2007 09:06 AM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
Multi Mono vs Multi Channel Plugins...Just curious... Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2002 09:46 PM
Calibrating meters with PT Signal gen: Difference between MasterBus and TrackChannel ODC Tips & Tricks 2 02-27-2002 04:53 PM
