Bug in Audiosuite processing stereo files in region bin 7.4
There appears to be a bug introduced in 7.4 (I'm on an HD rig, but I believe I've observed the same behaviour on a PTLE rig) in the handling of Audiosuite processes on stereo regions in the region bin, which makes batch processing of stereo files more cumbersome. Would appreciate confirmation from others.
In previous versions (up through 7.3.1cs5), you could select a split stereo file in the region bin, perform an audiosuite process on it with the "Playlist/Region List" selector set to "Region List", and you would get a split stereo file with the process name *pre-pended* to the final .L/.R suffix - this then behaved as a normal split stereo pair. Now, in 7.4 (up to cs3), when you perform the same steps, you get *two* files with the process name appended to the file name *after* the .L/.R designation - this means that the files are no longer treated as a stereo pair. Example: original split stereo is "Audio.L/Audio.R", it's selected in the region list and it is *not* on a track, and you're using the Audiosuite Gain plug-in with the "Region List/Playlist" selector set to "Region List", "Use in Region List" *not* selected. In previous versions the result would be "Audio-Gain-00.L/Audio-Gain-00.R". In 7.4 the result is "Audio.L-Gain-00 / Audio.R-Gain-00" If the Audiosuite plug is used on a file on a track with the "Region List / Playlist" selector set to "Playlist" things behave normally. Best, rich
Re: Bug in Audiosuite processing stereo files in region bin
As of 7.4cs6 this still doesn't appear to be fixed. It means that it's no longer possible to batch process stereo files in the region bin - this is a major drag if you need to batch process a pile of stereo files, you now have to drag them into a timeline and process one by one. Not fun!
Any word? best, rich
I feel your pain, Rich - this has been logged, but I do not have a specific timeline for a fix. If I do happen to hear anything, I'll be sure to let you know.
Great - really appreciate the update. I'll keep my fingers crossed that this happens soon.
best, rich
So is this *ever* going to get fixed?? I had assumed it would be worked out by 7.4.2, but alas, it's still with us. Had to batch process 30 mixes today - not fun...
best, rich
Looks like it's fixed in Pro Tools 8.
Hope it helps, Timothy |
best, rich
I don't think so.
What it does: If you have 5 stereo regions in your timeline selected, it applies the audiosuite setting to each region and creates 5 new processed regions, instead of 1 long coninuous region (audiosuite set to playlist). And Pro Tools will keep these regions as stereo files in the bin after processing. It does here anyway. Hope it helps, Timothy |
Region processing from the bin was previously the only way to maintain stereo processing linkage while batch processing stereo files - this is no longer possible and must be done on stereo files one at a time in the timeline now. best, rich
audiosuite region- file not in audio files folder | ec123 | Post - Surround - Video | 3 | 07-26-2009 10:40 AM |
Audiosuite and interleave stereo files?? | JLEpperson | Tips & Tricks | 1 | 06-28-2005 09:03 AM |
Audiosuite Not Processing | Lonnie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-27-2004 09:16 PM |
Audiosuite not processing | Allen Hallada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-06-2002 10:26 AM |
Audiosuite L1 processing 22K files | babyseal | Pro Tools TDM Systems (Mac) | 7 | 03-03-2000 12:08 AM |
