Export and Import to and from Neundo
Hi!
I'm travelling between two studios, one using Nuendo 2.1.1 on PC and one using PT 6.1 on Mac. How do I export projects from Nuendo to PT and vice versa. I've read about OMF, but I also read that it sometimes moves samples around and generally isn't too stable. Consolidating/bouncing is unfortunately not an option, since I need all the data for mixing. Does anyone have any experience with this, that they would like to share? Thanks in advance!!! Best regards Tommy Hjelm |
Re: Export and Import to and from Neundo
Sadly you have to buy OMF as an option for $500.while other applications include OMF. How sad!
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
According to the website, MM-EDL is for PC only...
Anything comparable for exporting from Pro Tools Mac to Nuendo? LT |
MAC REQUIREMENT
Hello,
Actually MM-EDL supports only MAC based Pro Tools sessions. The software runs on a host PC. Visit www.mm-edl.com There are many benefits found in the MANUALS section. |
Re: MAC REQUIREMENT
Here's the best way and safest... you won't bring over any of your mix or automation stuff, if you need that..
In Nuendo, bounce the tracks you want to bring over to PT. This will create a new solid file of all the regions you want to take. Have each track start at zero. Name your tracks really well, like "songname_trackname_takeXXX". Then, just dump the audio folders and take them with you. Then, in PT, just drop the files into your PT session and make sure they all line up at 0 (or whatever offset you want). I've found going between Nuendo and PT via built in imports and exports is a pretty good way to destroy your data! -Tom
http://SpeakRecords.COM |
Mxf import / export | JJG | Post - Surround - Video | 0 | 08-24-2005 12:25 AM |
OMF import/export | kmshroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-06-2003 09:23 AM |
OMF Import/Export with PT5.3HD? | Samhein | Pro Tools TDM Systems (Mac) | 8 | 03-28-2002 10:39 AM |
Mp3 import/export | kastlercreative | Digidesign Hardware & Software | 4 | 03-23-2002 05:13 PM |
export/import Q: | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-12-2001 09:44 AM |
