reason freezing protools
My Mac 733 froze for the first time in a protools session. I was driving reason from pro tools through the IAC bus. It worked fine for about 20 minutes then it froze solid-no mouse -no nothing. I have used this setup before with no problem -the difference was that I had three other musician recording at the same time. I cold booted and the same ting happened about 20 minutes later
Any suggestions as to a possible fix would be appreciated. Note to DIGI \; Rewire or DC I don't care but lets find a way to get these two great programs to work together in a more elegant fashion. [img]images/icons/smile.gif[/img] B
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers |
Re: reason freezing protools
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by b mcgibney:
My Mac 733 froze for the first time in a protools session. I was driving reason from pro tools through the IAC bus. It worked fine for about 20 minutes then it froze solid-no mouse -no nothing. I have used this setup before with no problem -the difference was that I had three other musician recording at the same time. I cold booted and the same ting happened about 20 minutes later.<HR></BLOCKQUOTE> Hi B, Were you driving Reason with just a MIDI clock from PT, or were you sending sequencer data from PT to Reason? And the three other musicians you mentioned - does that mean three audio tracks recording in Pro Tools? Or more audio tracks than that? Things that work for 20 minutes then don't are a huge pain to troubleshoot... Leigh |
No solution here, just a little "I feel your pain" message...(can't hurt).
I've experienced the same thing with DP+Reason via Rewire while recording a singer...very annoying and embarrassing (eventhough the singer was a good friend). The only difference compared to your problem is that I could force DP to quit (no "solid" freeze). Haven't figure out where the problem comes from yet; the only solution I found was to export the Reason sequence in DP to be able to record safely and quickly...pretty weak as a solution...
Some music?... http://tmweb.free.fr |
Protools and 003 keep freezing? | KevinAllen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-08-2010 07:36 PM |
pro tools 7.4 freezing with reason error | djkiller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-23-2008 02:53 AM |
Protools 6.4 Freezing | N@W | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-18-2006 08:58 AM |
G5 w/ 002, Protools keeps freezing PLEASE HELP!!! | gryzing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-20-2004 08:07 PM |
OT: is Reason 2.0 freezing anyone up? | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-03-2002 10:48 AM |
