Old 03-01-2022, 08:04 AM
beggar_amazing beggar_amazing is offline
Default Issue bouncing Same as Source on Catalina
Hey all. I'm trying to bounce a quicktime video using Same as source on Catalina. Running Pro Tools 2021.6.
The issue is that I keep getting the following error.
AVE reported an error at the completion of audio/video export
I've tried bouncing using Apple Pro Res (Proxy, LT, and 422). Same error every time.
I'm not able to find ANY info on what that error actually means!
Old 03-01-2022, 08:17 AM
Default Re: Issue bouncing Same as Source on Catalina
Real-time bounce, or off-line bounce? Try the other way if you haven't already. Next, try freezing or committing tracks(if that helps, then its likely a plugin)
Old 03-01-2022, 09:17 AM
Tried both ways, and also made a very basic session with just video and one audio track. No plugins....Get the same results. A real head scratch-er this one...
Old 03-20-2022, 09:30 AM
Tyler Erik Tyler Erik is offline
I'm suddenly having issues trying to bounce out a .mov too! It gets to the end, then gives me an "AVE reported an error at the completion of audio/video export" error message...
Old 03-21-2022, 07:12 AM
Just brainstorming, but is it possible that there are illegal characters in the file/folder/path name? I recall AVE being quite picky with characters in path names.
Scott Gatteño
Old 03-21-2022, 08:02 AM
gives's Avatar
gives gives is offline
I worked with Avid on fixing Bounce to QT. You will need to update your software to the latest or check the quality of your movie conversions. Are all of your movie files from the same supplier or is it just a particular version? I have no issues here, but maybe try checking the QT files maybe convert using ffworks which I highly recommend for converting or Shutter Encoder..
I see you are new to the forum, so WELCOME!
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 03-21-2022, 02:42 PM
smurfyou smurfyou is offline
Are you selecting just the actual video clip length?
~Will
Old 01-19-2023, 08:46 AM
nicolasvandooren nicolasvandooren is offline
I have the same problem.
I solved the problem by converting the original mp4 video file to mov. Then I've imported the mov file in Pro Tools. Then exported in mov.
Bouncing to MP3 issue Raoul23 Windows 5 01-12-2016 01:19 PM
11R clock source issue Legion6789 Eleven Rack 3 12-31-2011 11:38 AM
Clk source issue stevedresser83 Windows 3 05-07-2011 12:04 AM
Bouncing 2 source Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-21-2007 08:00 PM
need help bouncing from optical source ChrisO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-09-2002 10:46 AM
