Old 01-11-2016, 03:13 AM
lululu lululu is offline
Default main screen display option when selecting tracks?
When I select a track on the S6 surface it seems to focus on the sends in the main screen regardless of my selection on the channel strip. Is it somehow possible to change this so it shows whatever I have selected on the strip to be selected on the screen?
cheers
M
Old 01-11-2016, 07:42 PM
EddieJones's Avatar
Default Re: main screen display option when selecting tracks?
You can set the local home screen prefs up to show what you want and also a backup if the strip you attention doesn't have the default function in it. Coming in v2.2 there are preferences that auto attention and switch to the selected function when you press a strips function key. Also it will switch the KVM to the correct DAW.
Old 01-12-2016, 05:29 AM
Hi Eddie
Hope you're well and thanks for getting back to me.
I now found it, thanks.
It would be great though, if it would show the dynamics section of the channel strip when I have dynamics selected rather than default to EQ (I use a different EQ), but that comes down to channel strip not showing as a dynamic module on the S6 main screen I guess.... Would be good to change that though...
Looking forward to 2.2 with mirroring the function on the strip, which would be really useful.....
Old 01-12-2016, 07:45 AM
EddieJones's Avatar
Channel strip does show as a DYN plugin.
dual monitors PT slips to main screen lexaudio Pro Tools 11 4 02-19-2015 05:17 PM
Windows configurations screen weirdness/flashing when selecting crizdee Pro Tools TDM Systems (Mac) 2 03-28-2014 02:19 PM
Problem w/ main screen Duranet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-31-2012 02:39 AM
Plug-ins List display, view of the screen display andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-23-2007 03:24 AM
The main screen in PT isn't showing up? rightsidefalls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-01-2004 12:14 PM
