Old 11-28-2022, 03:14 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: structure crashes 1 incidence
Originally Posted by Fritz View Post
... Just really looking to replace a snare and kick in a track I have with my sample.
Slate Trigger 2 seems the most popular drum replacement tool – start with the free version:
https://stevenslatedrums.com/trigger.../#trigger-free
Trigger 2 Free is not compatible with Trigger Instrument Editor, which is required to load your own samples, but if you’re sufficiently impressed with Trigger Free, the full version (Trigger 2 Platinum) is currently on sale for $49
https://stevenslatedrums.com/trigger-2-platinum/
Use the updated Trigger Instrument Editor to design your own multi-velocity, round-robin drum samples to use in Trigger 2 drum replacer, FOR FREE!
https://youtu.be/aLWX2alev5c
How To Make Your Own Drum Samples (And Load Them Into Slate Trigger)
https://youtu.be/FqPV6RbXwTs
However, if you want to persevere with Structure:
https://duc.avid.com/showthread.php?t=376270
Originally Posted by Danatee View Post
For anyone trying to figure out how to load their own wav sample from a pro tools track into Structure Free I have found a method. Although all the Youtubes show that you can drag and drop directly, you can't. I found that what you need to do is the following: once you have your sample trimmed, highlight that clip and go to file>bounce to disk>choose directory(I created a seperate folder for my own samples) then click on Bounce. Now go to your folder and you can drag the sample to the patch box (black box upper left ) in Structure and Bingo! I hope that will spare others from tearing their hair out trying to find the answer!
Structure – Mapping samples
https://youtu.be/Z9bwpn77Nq0
Structure – Keyswitching
https://youtu.be/nnxFQfxuta0
Structure – Layering Sounds
https://youtu.be/hXhdZoSZNbo
Structure – Multi-timbral operation
https://youtu.be/wcMP0bQXsqk
Slice & Sample (Pro Tools Beat Guru)
https://youtu.be/IqC3pj3W-KI
Can I make a Structure patch with Structure Free?
https://duc.avid.com/showpost.php?p=1364422&postcount=2
Avid Knowledge Base – How to Get the Most Out of Structure Free
https://avid.secure.force.com/pkb/ar...Structure-Free
Old 11-28-2022, 03:35 PM
Fritz Fritz is offline
thanks for all the links.
tikety-boo as Cleaver says.
"Do not fear mistakes. There are none."
Miles Davis
Structure crashes PT when loading EXS patches Hanswurstlsepp Virtual Instruments 16 09-22-2015 01:04 AM
Structure 1.1 crashes PT 8.0.4 when click browser audiojavi Virtual Instruments 0 08-29-2010 06:41 PM
Structure crashes when trying to load Gigasampler patches lkingston Virtual Instruments 3 05-17-2010 02:48 PM
8.0.3 on SL: Structure Free crashes PT fenderrocker Virtual Instruments 10 04-08-2010 08:32 AM
Structure crashes PT8 when loading Hercules98 Virtual Instruments 2 04-08-2009 09:08 AM
