Old 08-20-2009, 04:53 PM
ChrisSimon ChrisSimon is offline
Default PT8, Sustain pedal, velocity problems while recording
Hi, I´ve trouble, while recording MIDI in PT8.. doesn´t matter if virtual Instruments or real MIDI Outboard Gear...
I use MacPro, Unitor 8 Mk2, 2 Amt 8s, connected as one big machine 24 MIDI I/O..
While playing along the PT Session, everythings´s fine, just when I record:
I get cutted sustain pedals, Velocity seems also sometines sound strange to me..but the worst is the Ctrl 64 (sustain).
Doen´t matter if my MasterKeyboard is connected via USB or MIDI...I also checked with several Keys....same problem...
Anyone an idea??
Hope to read from you...
Chris
Old 08-20-2009, 05:23 PM
DigiTechSupt's Avatar
Default Re: PT8, Sustain pedal, velocity problems while recording
Make sure your keyboard isn't set to use multiple zones, then go to Preferences>MIDI in Pro Tools and try changing the default midi thru instrument to either the first MIDI port for your keyboard or to first active MIDI track - one of those settings should fix the problem.
Avid Audio Tech Support
Support FAQ
Problems with MIDI Sustain Pedal while recording ChrisSimon Pro Tools TDM Systems (Mac) 71 06-25-2014 10:30 AM
Sustain Pedal Problems while rec. HORROR!!!! ChrisSimon MIDI 2 12-10-2009 02:09 AM
sustain pedal problems in 6.4LE tromostheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-29-2009 09:24 AM
Piano sustain pedal in recording Help!! Zownd Tips & Tricks 9 04-05-2004 02:21 PM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-09-2003 11:25 PM
