Old 04-29-2009, 02:42 AM
buckaroo buckaroo is offline
Default Best Transpose Plug in for PT?
Anyone know the best "transpose" plug in for Mac/Protools??
I mean a general Transpose plug in that does the most basic job of pitching audio up and down like a sampler, in semitones - but in the arrange window of logic/protools?
I dont mean any elastique/stretching at same pitch that every DAW does nowadays - I mean a simple plug in to go :
+1,+2, +3 up in pitch and sound gets shorter and higher
-1, -2, -3 down and sound gets lower in pitch and longer/deeper...
This is a bit like Ableton does when the warping is off, and also as Acid Pro does with "one-shot" samples..
I find it easier in the arrange window instead of loading up a sampler.. but Im on the Mac (so no Acid Pro) and want to use in PT
I cant find anything that does this without "warbling/strtching the audio? I have tried Elastic time with Varispeed which has no semitones value, and Serato which didnt do this...
Does waves soundshifter do this? and can it be demo'd?
Old 04-29-2009, 02:51 AM
Dirk Reinking's Avatar
Dirk Reinking Dirk Reinking is offline
Default Re: Best Transpose Plug in for PT?
http://products.zplane.de/index.php?page=elastiquepitch
Old 04-29-2009, 03:11 AM
Again surely this introduces artifacts as its elastique - does this do a simple tape / record deck slow down so i can play tracks at lower pitches with no artifacts ???
Old 04-29-2009, 03:20 AM
crizdee's Avatar
crizdee crizdee is offline
Waves sound shifter
Pitch n Time Pro
Xform
Elastic audio
soundtoys speed
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-29-2009, 03:28 AM
Thanks Crizdee
But again I believe all these effect the audio in some way???
By stretching etc.... Surely can a plug in do what ableton/Acid do with one shots where you can musically pitch up down like on a keyboard without artifacts??
Old 04-29-2009, 04:24 AM
Oliver M Oliver M is offline
Pitch 'n Time Pro does what you need, use its Varispeed Mode. Essentially you adjust the semitones range to be processed and then switch to Varispeed, it then speeds up the audio or slows it down. I use it all the time.
Oliver
Old 04-29-2009, 04:50 AM
Thanks but the Varispeed mode says its controlled by tempo??
Does it have an independent pitch in varispeed? AND can it audition alongside other audio in the timeline so you can match keys etc?
Old 04-29-2009, 04:55 AM
Sorry i see now - you move the tempo slider at the top to create a pitch change in varispeed...
BUT can you get this slider to show (and snap) to semitones? so i can go -1, -2, -3 etc?
At the minute its a little "free" and you cant pinpoint certain pitches
Old 04-29-2009, 08:47 AM
drenkrom drenkrom is offline
You could open a separate PT session, set your clock source to Internal/VSO and adjust your pitch with the VSO slider in the Session Setup dialog. That slider uses semitone/cents as its measure. You can record the output of that session to whatever other recording source. If you must have it in the same session, I'd personally recommend Pitch n Time, but most of the mentioned plugs should do the trick.
Any digital process that will affect sound duration or pitch will inevitably have artifacts, even Ableton and Acid. When you play with sample spacing, there's no way around it.
Old 04-29-2009, 11:01 AM
scottleader scottleader is offline
I like Melodyne personally...
Soundtoys is a good one too.
transpose Jel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-19-2009 08:44 PM
Transpose Audio (WAV, MP3, Etc.) BradyP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-12-2007 07:31 PM
How do I transpose.... Elton Hyland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-05-2007 10:32 AM
Pitch Transpose Roq_it Tips & Tricks 4 01-10-2007 02:15 PM
transpose audio how???? ellentibi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-02-2002 02:42 AM
