Old 06-02-2000, 07:43 PM
hit productions hit productions is offline
Default Generating Timecode from USD, Help
Hello,
I have been trying to generate Timecode from the USD using the System Setup window. When I select Generate TC using USD . . . Position Reference changes from LTC (my usual setting) to Generate.
The word "Generate" however is greyed out. Of course when you play . . . no timecode is generated.
I am able to generate TC by using manaual (non-remote) mode. All other functions of the USD work normally.
My system . . . G4/400, PT Mix Plus, USD connected to Digiserial Port.
Thanks in advance! Any suggestions very appreciated.
Sincerely,
Dennis Cham
Old 06-02-2000, 08:02 PM
DigiTechSupt's Avatar
Default Re: Generating Timecode from USD, Help
Dennis,
Make sure that pro tols is "online" when you are trying to generate from the USD.
Sounds like your settings are correct other than being online.
B Carter
Digidesign
Avid Audio Tech Support
Support FAQ
Old 06-04-2000, 02:17 PM
Thanks B Carter!
It worked!
Dennis
Generating Timecode With LE patsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-10-2008 03:48 PM
Generating SMPTE Timecode in PT Adam Ings General Discussion 2 11-24-2007 02:25 PM
Generating timecode JohnGreenham Pro Tools TDM Systems (Mac) 2 07-26-2005 04:25 PM
SSD generating timecode? [email protected] Tips & Tricks 1 09-01-2000 11:19 PM
USD and Generating Timecode Scotty Tips & Tricks 3 09-01-2000 03:35 PM
