Old 01-31-2013, 01:27 PM
P,B,S P,B,S is offline
Default AAX PLUGIN SHORTAGE, was it the same way the last time the format changed.
Just wanted to ask that because I wasn't using PT then . My geuss is it was the same way and us leading edge people had the same problem. If it was the same way is it not logical to assume or believe that after a while (year or so longer) we should probably see alot more plugs being offered.
Or was the change over instant. From my reading on the web it wasnt and this is nothing new. So why is everybody surprised. Had I known I would have still wanted HDX but I may have waited a while longer.
Old 01-31-2013, 03:52 PM
ilulilu888 ilulilu888 is offline
Default Re: AAX PLUGIN SHORTAGE, was it the same way the last time the format changed.
nope - it was worse......people tend to forget that 11 years ago when PTHD came we didn't have that many plugins available in the first place...i remember waves (they had 20+ plugins) bombfactory and some plugs from drawmer focusrite and mcdsp.....but if i remember corectly the total amount of plugins that were available back then was around 70.....so by now - we have over 80 plugins in AAX DSP ready to go and over 100 AAX native plugins at least....so there are more then enough plugins out there to use HDX....
Pro Tools 12HD
HDX 1
Avid HD 8x8x8
Avid Omni HD
MacPro 2.4 Xeon 8 core 24Giga
UAD-2 And most of the UAD plugins
All AAX DSP and Native Plugins (all most)
Tons of Hardware...:)
Old 01-31-2013, 04:20 PM
Emcha_audio's Avatar
last count was 93 dsp plugs.
Manny.
Wave-T.com
Old 01-31-2013, 04:33 PM
elicious elicious is offline
member also, os9 changed to osx soon after...
major holes in all sorts of apps and plugs.
first plug i bought for hd was spectra foo;
it was broke for years.
e
ihatetyping
Old 02-01-2013, 09:47 PM
roberts roberts is offline
and it was half that a year after HD TDM came out.....
Old 02-02-2013, 02:49 AM
Yep
Manny.
Wave-T.com
Old 02-02-2013, 10:35 AM
So this current situation is just normal then. Not out of the ordinary, even if surprising and unexpected.
Old 02-02-2013, 10:39 AM
crizdee's Avatar
crizdee crizdee is offline
But mix systems already used TDM plugins and there were no RTAS at the time and the amounts invested in plugins at the time was a lot less, digital recording and mixing wasn't as big as it is now and the plugin fest hadn't really started, people were still doing what they did with hardware and used maybe 2-3 plugins on a track so the cross-over wasn't as painfull. the biggest issue people have is not the shortage of plugins for HDX DSP but that they have $1000's invested in plugins that they own and like and have all over their sessions and want to keep using and many of the companies haven't committed to HDX yet! let alone DSP versions.
We're in an interim period and native is probably enough for a lot of users who want HDX now! but when 11 drops and Avid wants everyone to upgrade then those companies need to be onboard the DSP wagon. mosty native will work for a lot of peoples work flow but not everyone.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-02-2013, 10:51 AM
TOM@METRO's Avatar
It's not unexpected at all. This entire PT10 era has been just an introduction to HDX and the future of Pro Tools in General. When a new 64bit pro Tools hits the streets, the game will undoubtedly change. Until then, it's just a warm up.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2023 HDX Hybrid
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-02-2013, 12:02 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Compatibility with future AAX-only plug-ins are the only reason PT 10 needs any AAX plug-ins. Most AAX discussion is about vapourware unless it applies to the tiny few early HDX adopters.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
message reads I/O setup has changed since last time session was opened last time peteor96 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-05-2011 08:29 PM
Your I/O setup has changed since the last time this session awalls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-05-2011 07:49 PM
Format cannot be changed - setting up inputs trock Pro Tools 9 0 11-05-2010 05:14 PM
Shortage Of HD?? Exxtreme Pro Tools TDM Systems (Mac) 0 07-24-2002 07:13 AM
has SampleCell CD format changed in 10 years? lesCaudle Digidesign Hardware & Software 2 12-12-2001 07:21 AM
