The Infamous CPU Errors
Hello Guys,
Would very much appreciate some insight to a problem with my Pro Tools set up. Having searched through this forum and various others it seems Im not the only one running into the cpu errors (-9128) but at the moment I haven't found a solution to this. Here is my set up: Mac 10.5.8, 2.66 GHz Intel Core 2 Duo, 4 GB 1067 MHz DDR3 Pro Tools 8.03 LE with Digi 002 Rack I have tried various settings on the playback engine options. Usually when mixing I have it set to: 1024 Samples, 2 Host Processors (my maximum), CPU Limit 100%, DAE Playback Cache at level 2 normal, Plugin-In-Stream at 2. During playback the mix stops after a few seconds: "Remove RTAS Plugin or Increase CPU". Of course the CPU is set to the maximum and the vast majority of plugins are set to "inactive" but the error persists. On this specific session there are only 4 tracks, the "system usage" meter shows the CPU (RTAS) at around 10% yet another sessions of mine has this reading at around 50%! and manages to play longer? I have read certain plug-ins could cause this error, would it be wise to remove my plug in folder from the mac HD temporarily? (its 2.5GB) I am recording to my external lacie drive, could I place the plug ins there for pro tools to read? Thanks for any thoughts they are much appreciated. |
Re: The Infamous CPU Errors
I take it all of the smart US folk are sleeping at the moment ... come on guys we can do it
Have you tried to enable "Ignore RTAS errors"? Quote:
To disable a plugin, just move it to a different folder. I have a "Inactive" folder next to the "Plugins" folder. Important to remember: when troubleshooting plugins, you have to qiut PT, thrash PT/DAE prefs, and relaunch PT. You'll notice that PT rebuilds the PI menus/database that way. IHTH.
Thanks for the prompt reply Ben I appreciate it very much
Im going to sort out the plug ins folder and see if that sorts anything out. Im aware of leaving 1 free core, I have tried this but the cpu meter goes crazy when I switch to 1 (it moves all the way up to 100%) I will take your advice and switch on the "ignore RTAS errors"; should this always be on? When recording I remember getting lots of odd noises with this feature enabled. Thanks for the tips mate .. I will trash the PT/DAE prefs and sort out the plug-ins. Just a quick question should plug-ins in genreal be saved on the main HD or is it possible to have pro tools look these up for the external drive I record to? (I assume this doesn't affect CPU power). |
That means that you have to be very aware of what's going on with the CPU. I would check the Activity Monitor application to see what other processes are active and using power. Perhaps you can disable something. Quote:
They must be in the default folder. I guess you could move them to a different disk and create an alias to put in its place, but the location of plugins on HDs is really irrelevant, unless the HD is getting full wich would be a serious problem for the mac as a whole, and you would have to resolve. The disk containing the OS should always have lots of free space. I would say at least 20%.
i would recommend you go to update to 8.0.5. Also set your CPU to 95% not 100%. You need to leave the system some percentage to function since you are allocating both processors to pro tools.
Chris
http://www.youtube.com/user/RegenerationMix http://soundcloud.com/regenerationmix http://twitter.com/regenerationmix MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7 |
Thanks for the help Ben and Chris its very much appreciated, I've removed certain plugins and installed the update 8.05.... no problems as of yet
Just two quick questions: 1. The CPU (RTAS) meter on the system usage is still hitting around the 50% mark with the 2 cores (my maximum) on and shoots up to around 90% with only 1 on which is what avid recommend, so I am only working with the former setting as I can at least get to playback and mix like this. Would I greatly benefit from upgrading my mac for more processing power, I hear some people bounce each of their tracks and then open up a new session for mixing do you guys do this? what does your cpu read while mixing in general? 2. Having read the plug in compatibility table, a few of my plugins are out of date just a quick example my PSP Vintage Warmer2 is version 2.1.4 and on the table they state 2.5.2, would something this simple be the cause of these errors? (http://avid.force.com/pkb/articles/e...ility/en343311) Hope everyone is well and thanks again for the input you guys are great |
My Pro tools started producing more and more CPU errors than ever, recently. I was also getting the "rainbow wheel" just using the Macbook in general. Took a trip down to the Apple store for system and software updates. Cleared the cache, disk repair, etc. Pro Tools is running great now.
Infamous Error code -7 | FuProtools | Pro Tools SE and Essential (Win) | 11 | 10-28-2012 01:59 PM |
Infamous DAE errors (90XX); Tried everything | D-ROCK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-19-2012 05:51 PM |
The infamous Mr. Carrington gets some time | Noiz2 | Post - Surround - Video | 8 | 01-12-2010 11:28 PM |
The infamous paint fade! | nemisis63 | ICON & C|24 | 1 | 08-22-2002 05:09 PM |
Infamous Dissappearing Region Bug | Sonsey | Pro Tools TDM Systems (Mac) | 1 | 11-29-2001 11:00 AM |
