Old 03-20-2012, 06:38 AM
RTASW RTASW is offline
Default Headphone Amp With Digi 002 Rack
Hi there folks,
I'm wondering what the best way to wire my new Behringer Ha800 headphone amp would be with Digi 002.
Previously I just had a little stand alone 4 way Headphone Amp but as the Ha800 is rackmountable I want to put it in their and connect everything at the rear to keep it nice and tidy.
I currently run my Speakers through the Monitor Out, should run this signal through the Behringer firsy then to my speakers or use the Main Out's instead? I assume if I use the main outs though the controls on the Digo 002 (ie; Mono, Mute and Level) won't effect the signal going into the headphone amp?
Very grateful for any advice of examples of how other's do it.
Thanks.
Pro Tools HD Native Thunderbolt, HD IO 8X8X8,ProTools HD 10.3.0 External 1 TB Storage, Apple Mac Mini Processor 2.6 GHz Intel Core i7 Software OS X 10.8.2
Memory 16 GB 1600 MHz DDR3
Old 03-20-2012, 07:41 AM
Default Re: Headphone Amp With Digi 002 Rack
Whichever output follows the 002 volume knob should feed your monitors. Use the other set to feed the headphone amp. You want to be able to adjust your monitor volume without messing with the headphone volume(use the knob on the Behringer for that adjustment).
Old 03-20-2012, 08:30 AM
Bill Denton Bill Denton is offline
I have a 003R, but maybe this will be of some use...
The 003R has two headphone outs, with headphone 2 switchable to 3/4 out. So, I just feed my headphone amp with 3/4. That way I can adjust/listen to the headphone mix by plugging into headphone 2 on my 003R.
Hopefully this will help some...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 03-20-2012, 12:05 PM
That would be a great option except the 002 doesn't have the extra phones output like the 003. Lots of deals on used 003's out there
Old 03-27-2012, 12:52 PM
BroomPole BroomPole is offline
I have a 002 with a HA400. I found the easiest solution was to just run a short TRS patch from the headphone out on the 002 to the Main in on the front of the HA400. It's not perfectly tidy but it does the trick.
Old 03-27-2012, 04:45 PM
GeoffLee GeoffLee is offline
Just use Main L-1 and Main R-2 if the musicians are sharing the same mix as you. It's independent of the volume knob.
Otherwise you could set up pre-fader sends to physical outputs (say 3+4) and patch outputs 3+4 to the headphone amp. Viewing the sends as faders makes it easier to set up a headphone mix. Only works if Low Latency Monitoring is not selected and you have a low buffer setting. You'll need to be wearing cans patched into the headphone amp to hear what you're doing!
Digi 002 Rack SPDIF Out not sending to my headphone amp Robusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 07-06-2013 11:27 AM
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-12-2012 11:34 PM
Digi 002 Rack Busted Headphone Jack digijohn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-28-2011 01:07 AM
Headphone jack repair - Digi 002 rack -expensive? worth it? captain54 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-03-2011 09:09 PM
Headphone - loss of channel in Digi 002 rack PacoPoblano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-27-2008 09:53 PM
