Go Back   Avid Pro Audio Community > Dev > Pro Tools Scripting SDK Toolkit
Old 02-03-2023, 04:01 AM
swappl swappl is offline
Default Authentication error 'Request refused. SDK versions mismatched.'
Hi there,
I'm trying to connect to the API, but getting the follwoing error message:
Code:
"response_error_json": "Request refused. SDK versions mismatched."
What does this mean?
Thanks,
Steffen
Old 02-03-2023, 05:52 AM
Default Re: Authentication error 'Request refused. SDK versions mismatched.'
I found out what's missing...
The version attribute in the header!
When sending the following:
Code:
  "header": {
    "command": 60,
    "version": 1
  "response_body_json": "{\"auth_string\":\"<my-auth-key-json>\"}"
with my-auth-key-json like this (escaped, of cause):
{"schema":{"version":0},"company":{"name":"<NAM E-HERE>","x509_certificate_chain":["<BASE64-HERE>"]}}
I receive an other error:
Code:
  "header": {
    "task_id": "bb74154b-054f-654b-8b80-6f1f6eb9c257",
    "command": 60,
    "status": 4,
    "progress": 0
  "response_body_json": "",
  "response_error_json": "\n{\n  \"command_error_message\":\"auth_string\",\n  \"is_warning\":false,\n  \"command_error_type\":\"PT_UnknownError\"\n}\n"
So, what's an example of a working AuthorizeConnectionRequest???
Old 02-03-2023, 12:52 PM
JamieHardt JamieHardt is offline
How are you serializing the JSON request? You have to make sure the auth_string value is all escaped properly, and your protobuf JSON mapping is including default values for fields, preserving protobuf field names and ignorning unknown fields.
___
Jamie Hardt MPSE
Pro Tools Ultimate 2022.12.0
Mac OS X 12.6.2
Mac Pro (Late 2013)
Old 02-21-2023, 04:37 PM
rmajors's Avatar
rmajors rmajors is offline
Hi swappl,
Have you been able to work through this issue? Please let us know if you need any assistance successfully establishing a connection to Pro Tools.
Best,
Rob
Rob Majors
Avid Software Engineering
Pro Tools 10 software - Authentication Error imranlk Windows 3 06-18-2012 08:37 PM
Why? (request for future versions) *DELETED* c-tone Pro Tools TDM Systems (Mac) 11 08-14-2007 09:20 AM
Protools refused to load. QuietLikeaCrow Pro Tools M-Powered (Mac) 1 08-08-2006 10:56 PM
D-Fi 7.0 : authorisation refused after update dolby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-20-2005 03:12 AM
