Old 01-28-2023, 07:02 AM
ReynaldoPena ReynaldoPena is offline
Default MIDI Learn/Assign CC, Not Working (S49, Mpk3 Mini)
Anyone had any issues with assigning buttons on a MIDI? I tried using the learn button as well as assign CC's and it's simply not responding. I had to resort with avid control to latch automation.
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 01-28-2023, 10:06 AM
Default Re: MIDI Learn/Assign CC, Not Working (S49, Mpk3 Mini)
Hmm, maybe more detail on exactly what you are doing(and using) would help? From my own experience with Midi Learn:
1-not all plugins have this feature(which you may already know)
2-can you set anything up so it works at all?
3-if you can make things work, but they stop the next time you want them to work; once its setup, save a Track Preset. I used to use a VOCE Midi drawbar box and I could get everything to control DB-33, but the next time I put DB-33 on an instrument track, nothing worked. BUT, once I save a Track Preset, any time I needed DB-33 in a session, calling up the Track Preset(instead of a new stock instrument track), everything worked Hope this can help you
Old 01-28-2023, 08:55 PM
unkJE's Avatar
unkJE unkJE is offline
Originally Posted by ReynaldoPena View Post
... I had to resort with avid control to latch automation.
Until this is fixed, you might like to try a Demo of Blue Cat's Remote Control - virtual MIDI Control Surface (VST, AU, VST3, AAX)
Demo Downloads (above System Requirements) here:
https://www.bluecataudio.com/Product...RemoteControl/
Demo Limitations:
• Limited number of instances of the plug-in per session.
• The application or the plug-in is regularly bypassed for a few milliseconds.
User Manual:
https://www.bluecataudio.com/Doc/Product_RemoteControl/
Blue Cat's Remote Control, The Virtual Control Surface Plug-In In Action
https://youtu.be/13lwpwTsLZc
Tutorials - Tips:
https://www.bluecataudio.com/Tutoria...RemoteControl/
Pro Tools Ultimate 2023.9
Map Akai Mpk3 Mini pads in GrooveCell ReynaldoPena Virtual Instruments 2 07-02-2022 07:58 PM
Learn Mode in EQ3 plugin not working j20056 macOS 5 10-14-2014 06:57 PM
Midi Learn No Longer Working ersalmon Windows 1 02-03-2013 10:13 PM
MIDI Learn on Axiom 49 (regular) and MBox Mini PT8 spamshine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-26-2010 11:52 AM
How to assign MIDI CC to plugin parameters if no MIDI Learn? Mitch Manger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-25-2007 11:10 AM
