Old 01-26-2023, 12:03 PM
jschmit jschmit is offline
Default Alt 5.1 mix via HDMI?
I have a question about sending an additional 5.1 monitor output from our system. Currently we are running PT Ultimate with a MTRX Studio and a Mac Mini. Monitoring is configured using some of the analog outputs from the MTRX. We would also like to send the 5.1 mix out into the studio along with a video monitor output from the Mac mini via HDMI. Is it possible to set this up using the AUX I/O feature? The HDMI cable is running to an Extron podium system that has a surround processor that feeds speakers in that studio space. I’ve been told that the audio signal has to travel on that HDMI cable to get into the Extron system. They haven’t provided any other way to bring it in.
I’ve done this with my laptop with a stereo signal using PT Studio. The system with the MTRX involves DADman and a 5.1 mix and thus I’m not sure if it’s as simple.
Old 01-26-2023, 07:10 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Alt 5.1 mix via HDMI?
Sending digital surround means you need to encode it on your alt.master (not sending discrete channels)
Janne
Old 01-26-2023, 09:14 PM
Dizaineris Dizaineris is offline
Heres a possible solution.
https://www.blackmagicdesign.com/pro...pecs/W-DLUS-13
Then use Aux I/O to setup another set of outputs routed to Blackmagic device
HDMI Audio Outputs 8 Channels embedded in SD/HD
USB-HDMI adapters???? albee1952 Pro Tools HDX & HD Native Systems (Win) 14 10-17-2013 06:33 AM
anyone have any experience with Arvus HDMI-2a HDMI to 8 ch AES Craig F Post - Surround - Video 0 12-17-2012 04:24 PM
wireless HDMI Craig F Post - Surround - Video 2 04-20-2011 11:51 AM
USB to HDMI lode Post - Surround - Video 5 11-17-2008 12:00 AM
Asus m3n-hd hdmi ??? halipino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 08-01-2008 10:06 PM
