6.4.1cs2 Output levels still drop upon reopening
So I'm still getting output level changes using 6.4.1cs2. Creating a new session using +12. When I go back to that session the output levels are WAY low, until I change "number of Voices" (which closes and reopens sesion). Then everything is fine. This is REALLY frustrating. Any plan to fix this bug DIGI?
Tim OS 10.3.4 PT 6.4.1cs2
Tim Reisig Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram) |
Re: 6.4.1cs2 Output levels still drop upon reopening
what converters are you using?
FWIW the levels are low on the Master fader as well. Tim
Update: I just created a NEW session with +12 faders and IT had the low level output issue as well. When I switched number of voices (from 64 to 32) when the session reopened all was fine. So apparently it doesn't have to do with sessions converted from +6. To reiterate: I put signal gen up on a channel and create a master track. level on sig gen track is fine, level on master track is WAY LOWER. Also levels coming from AUX sends going to outputs are WAY LOW. Does NO ONE ELSE have this issue with 6.4.1?
Tim
Just to verify something, try this -
Open the HW setup dialog "undeclare" your interfaces (you don't have to close the dialog) "redeclare" your interfaces close the dialog Anything different? Danny Caccavo Digidesign |
This fixes the low level output as well (after it reopens your session).
Tim Quote:
Just to confirm Danny, redeclaring interfaces brings the output levels back to normal (without having to close and reopen more than once). But the problem DOES return fairly regularly. Let me know if you can recreate it.
Again here's my setup: OS 10.3.4 PT's 6.4.1cs2 Mix Farm-888/16 D24-882/16 Vintage Farm-882/20 Tim Quote:
Bump for DIGI reply.
Can you confirm this? Danny Caccavo Digidesign |
Actually I opened a newlly created +12 session template (as an notepad). The level was low. I re-declared an interface. All was well. I quit protools. I opened the same +12 template again and level was low AGAIN.
Tim [/QUOTE] Keep an eye on what happens if you change from a +12 session to a +6 session. I think that if you redeclare your interfaces for a +12 session, all is well until you go back to a +6 session..... Can you confirm this? Danny Caccavo Digidesign [/QUOTE]
Sound output error in Win7 64k, HD1 and PT8.1cs2 | ynor | Pro Tools TDM Systems (Win) | 2 | 01-11-2011 03:20 PM |
Busses Changing Levels When Reopening After Saving Mix | Meltdown | Pro Tools TDM Systems (Win) | 11 | 01-11-2010 07:09 PM |
Losing Video Output - 7.3.1cs2 | NTK | Pro Tools TDM Systems (Mac) | 13 | 07-07-2007 10:18 AM |
Drag and drop crash in 7.1cs2 | Dr. Marius | Pro Tools TDM Systems (Mac) | 7 | 01-16-2006 08:47 AM |
4dB drop in output, am I missing something? | district | Pro Tools TDM Systems (Win) | 3 | 10-26-2005 06:41 AM |
