Old 12-09-2021, 06:37 AM
siuberto siuberto is offline
Default Why do inactive tracks show up when I open my project?
I use a lot of midi tracks which I end up converting to audio tracks. However I’d like to keep the original midi tracks accessible just in case. I’ve noticed that whenever I open up my ProTools projects many of those inactive midi tracks pop up back again in my project not necessarily as active but just taking up space inside the project. How do I stop this from happening? Thank you very much in advance.
MacBook Pro, OS Catalina, Focusrite ISA 220, UAD2 Quad, Pro Tools 2020.11
Old 12-09-2021, 07:39 AM
Default Re: Why do inactive tracks show up when I open my project?
Which exact version of Pro Tools?
Did you save after hiding these tracks?
Do you mean "session" when you say "project"(I ask because a project lives in the cloud, while a session lives on your local hard drive). If you do mean projects that live in the cloud, then this might be a simple limitation of how projects are saved. Personally, I want my work on my hard drive, so I only use sessions, and back them up to multiple locations. For collaboration, instead of using projects in the cloud, I will upload a session with dropbox, wetransfer.com or similar.
Old 12-09-2021, 09:28 PM
Ben Jenssen's Avatar
I've seen this. Also folder tracks that are collapsed come back un-collapsed on re-open. I just live with it. Sloppy programming.
Old 12-10-2021, 07:37 AM
I meant SESSIONS not projects in the cloud. Yes I do save work on external drive. I also have the option of backing up sessions onto Dropbox. Having said all this, does anyone know if this constant popping up of inactive tracks into my session is a problem that can be fixed from my end?
Old 12-14-2021, 12:30 PM
Thank you for your replies. I still need to explore this further so any additional insight would be appreciated. First to answer your question. I have version 2020.11.0. Second, I am referring to Sessions (not projects). Lastly, most of the recurring inactive track are tracks that were initially Virtual Instrument tracks which I later “committed” to audio.
As a quick test, I went ahead and “hid“ the unwanted tracks one more time. And then I saved the session. Then when I went to close ProTools I saved it again when I got the usual dialogue checking one last time if I want to save the project. At that point when the file opened it was clean and did not have any of the issues. I wonder if this is the solution- that it’s requiring me to do that double safe routine in order to avoid the problem. Is this issue familiar to anyone? I’ll be keeping an eye to see if the problem is solved by double saving.
Old 05-26-2022, 11:19 AM
jeffro's Avatar
jeffro jeffro is offline
Did you have Source Tracks set to Hide and Make Inactive when you did the Commit?
File Type: jpg Screen Shot 2022-05-26 at 11.16.55 AM.jpg (24.0 KB, 0 views)
linkedin
After update hidden and inactive tracks show on s1\dock\control app ramonetl Avid S1, S3, Dock and Control App 7 06-26-2020 10:29 AM
suddenly can't make tracks inactive..it thinks they are inactive but they are active? awritersparadise Pro Tools 2019 0 08-27-2019 12:23 PM
Show and hide Inactive tracks dont work amolin Avid S4/S6 7 06-06-2016 09:45 AM
Pro tools 10.1 I open session tracks wont play says output map is currently inactive shamanrock Windows 16 01-23-2013 06:22 PM
OPEN WITH TRACKS INACTIVE???---snow leopard is biting my foot (& tracks) stormmusic Post - Surround - Video 2 10-09-2009 04:43 PM
