Old 05-12-2008, 12:21 PM
Andy Gerome Andy Gerome is offline
Default Freezes - Turns white - Loss of control 7.1 LE Mbox 1 *DELETED*
Post deleted by Andy Gerome
Old 05-12-2008, 01:01 PM
spkguitar's Avatar
Default Re: Freezes - Turns white - Loss of control 7.1 LE Mbox 001
Could I ask you to not use the "001" when referring to the original mbox? The 001 is a separate Digidesign product, and not related at all to the mbox. It's can be very confusing if you mis-represent them, even in just the subject field.
The tokens issue is from the MCU. Read this support article.
You are using the External drive for Pro Tools audio sessions? Your external drive is a USB drive. USB drives are not supported or recommended for use as audio session drives.
Old 05-12-2008, 01:10 PM
timebandit timebandit is offline
when you mention the '82 byte tokens' error that makes me think of this which mentions a problem when using HUI control surfaces - which you are.
Do you get that error every time? Try that and see what happens - or else try running the same session without the controller.
Also, I am not sure if you are running audio sessions from your external drive but USB isn't officially supported for doing so.
Post back if you have any luck with the solution above.
oops, guess I type too slowly!
Tom Lynn
my music:
www.tomlynnmusic.com
other people's music:
www.headphonomenon.com
Random GUI Freezes and Loss of Audio MBP The Dougfather 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-02-2009 03:18 AM
MBox turns on, MBox turns off Bonjourmate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-25-2008 11:54 AM
Help with Mbox 001 - Where is ASIO control panel? *DELETED* *DELETED* Andy Gerome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-28-2007 12:44 PM
White Noise (static) on Digi 002 Mic inputs 3 & 4 *DELETED* elankf1 Pro Tools M-Powered (Mac) 1 11-01-2006 10:16 AM
Playback turns to white noise Mbox/OSX/6.0 Eric R. Fischer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2003 11:13 PM
