combine two mono files into one stereo file [solved]
I see that Pro Tools can strip a stereo file into two mono files. But what about the other way around? I would like to take two mono files and have them join to a stereo file (without bouncing to disk, processing anything, etc.)
For the time being I have been using Audacity to do this sort of thing, then opening the converted stereo file back in Pro Tools. Should I make a feature request? Any suggestions? Thanks, |
Re: combine two mono files into one stereo file
Select the two tracks in protools sample bin or select the 2 regions in your arrange window, go to the regions pulldown menu at the top of the sample list, select "export regions as files", select "Stereo" and bitrate then direct where you want the file i.e desktop.
Okay yeah I know about that. That still has to process over time to complete. I assume then there is no quick way to just join two mono files together to stereo, inside a session. Hmmm...
Create a new stereo track, select all the regions on your two mono tracks (in order, with the L above the R), drag or copy them to your new stereo track.
If there's an automatic function for this, I don't know it. But that would be a nice feature. Could get tricky though if the tracks have different inserts, sends, i/o, etc. Cheers |
re-name the first mono track HELLO.l and the 2nd mono track HELLO.r
hey presto...
Mac Computers/PT12/Lots Of Lacie D2s |
Feature Request: Combine two mono into one stereo track? | cprescott1972 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-29-2020 11:31 PM |
How to combine stereo signal on mono track? | highpass | Pro Tools M-Powered (Win) | 5 | 02-26-2013 08:06 PM |
Question - Can I combine two mono tracks to a stereo? | tendb | Tips & Tricks | 1 | 04-04-2007 08:51 AM |
CONVERTING STEREO WAVE FILES TO MONO PRO TOOL FILE | T.W. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-25-2006 01:21 PM |
How to combine 2 mono wav files into 1 mono file | sjmonty | Pro Tools TDM Systems (Mac) | 10 | 11-13-2004 07:50 AM |
