Loud white noise
I get an unexpected blast of very loud white noise on playback after I've been editing for a while. All channels shoot into the yellow on the VU meters. It's intermitant. If I go back and start from a different place in the track, sometimes it doesn't happen. Sometimes it will be playing along fine and then it comes to a place in the track that I've edited and POW - the noise kicks in. I'm using a Powerbook with lots of memory with a Firelight drive with an Mbox. I just upgraded to Protools 6.01 and things are more stable, but this loud noise thing still happens. So far it doesn't seem to damage the file.
Any help on this? I read the topics and I see that this sort of thing happens with Wave - but as far as I know, I don't have this.
Bob Danziger |
Re: Loud white noise
Bob,
How is your Firewire drive formatted? Make sure all of your drives are formatted with Disk Utility in OS X as HFS+ volumes. If the drive was originally formatted in OS 9 or with onther utility you should backup and reinitialize the drive and give it a try. Mike |
Bob Danziger |
Bob Danziger |
Thanks Mike, I'm not sure how my FireLite is set up but I'll check it out right away.
Bob D
Bob Danziger |
Your FireLite will not work with ProTools 6/OSX. It does not meet the requrements for an audio drive as it's only 4200 RPM and has no Oxford 911 chipset in the interface. I used to use mine with OS9/ProTools 5.2 but had the same problems with OSX/ProTools 6. Buy a qualified drive and you'll be all set. Your drive needs to be at least 5400rpm, preferrably 7200rpm, and must have the Oxford 911 chipset in the interface. A cool bus powered drive that qualifies can be found here:
http://eshop.macsales.com/Catalog_It...=OWCMOFW60GB72 I'll be gettin one of these suckers as soon as I sell my FireLite. Cheaper firwwire drives that qualify can be found all over. I also just bought one of these and it works great so far: http://aicmicro.com/productdetail.asp?id=10129
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
hi , i've just installed OS X and ProTools 6.1.2 this week and have experienced the intermittent white noise blast (as it's being referred to). This did not happen in OS 9.2 with ProTools 5.3. My first inclination was to suspect that it was lack of RAM. However, upon recently seeing the plethora of posts about this problem for the last year or more, it seems we have a much more elusive problem. Considering that I just finished talking to the people at WAVES, who pleaded ignorance about any possible conflicts between their plug-ins and OS X, they are either extremely ill-informed or they are lying.
I have reformatted my recording and operating drive but I have not reformatted my firewire drive which I use for storage only. Does anyone know: Is having the firewire drive connected or pulling old sessions off the firewire drive and re-saving them on the reformatted drives going to be problematic (i.e. create the white noise glitch)? Is the problem having the 9.2 drivers anywhere near a session? Will more RAM help? I'm running 1 gig on a 867 MHz machine (dual processor G4 LE 002). I have the basic Renaissance reverb/compressor/EQ. --Kev |
This happened to me the other night when I went into Standalone mode?
Had to reboot the Digi 002. SG |
are you thinking that the problem might be with the 002?
Robert,
It is possible you may have the older version Waves shell - I'd check with them again (may be a new guy), I ran into the noise bursts using Waves after going to v4 & OSX... they also have the most recent shell on their webpage for download if you wan't to skip the call. Good luck! HH |
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini | Bigpit | Windows | 1 | 09-09-2013 09:26 AM |
LOUD Audio white noise? | jflowers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-31-2012 11:01 AM |
Loud White-Noise Sound | D-Synth | Pro Tools M-Powered (Win) | 5 | 04-25-2010 12:22 PM |
Loud white-ish noise when re-amping with 192 IO | brianjanthony | Pro Tools TDM Systems (Mac) | 2 | 11-28-2005 05:55 AM |
