Old 05-12-2023, 05:51 PM
milesofwire milesofwire is offline
Default Pre still supported?
Is the Digidesign Pre still being supported? Mine has the signal leds and the bottom range of the level meter flickering constantly.
Would like to know if it’s something that can be corrected.
Power supply maybe?
Old 05-12-2023, 07:53 PM
Default Re: Pre still supported?
https://avid.secure.force.com/pkb/ar...-support-dates
But what does that mean? If you want to go that route you need to find an authorized repair center, and are you willing to say spend $500 to $1k to get this fixed?
If you can't fix it yourself or find an low-cost independent electronics repair center and have them fix it at low cost then toss it out and buy a used replacement. The ones I see kicking around for $500 or less are going to be less cost then having any official repair work done.
Is 10.2.4 supported? Tillo macOS 9 04-26-2017 10:45 AM
C24 supported 11 and on? fasttraxx ICON & C|24 21 05-16-2012 05:41 PM
last supported os's erni Digidesign Hardware & Software 1 05-10-2001 07:36 AM
2nd IDE HDD not supported BMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-27-2000 05:51 AM
why is os 9.0 still not supported? slinky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-21-1999 10:59 PM
